Question about Hardware & Accessories
H3CR 11 pin
I need to add a buzzer or light to inform me that my oven batch timer has activated.
  • Gazz Jan 22, 2013
    Many thanks. I added a relay to the circuit when the power is dropped the NO / NC / COM switches over and I used another power supply within the cabinet to feed a buzzer and flashing beacon through the relay. Sorted!!
  • 5,245 Answers
1) When oven turns ON, Power flows between the timer and the oven.
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) For example the oven might be connected to pins 8 and 1.
Connect a light bulb to terminals 8 and 1.
http://waterheatertimer.org/images/10-pin-wiring-350.jpg
3) Since the H3CR timer is rated max 16 amps, I suspect the timer controls a contactor and is not directly attached to heavy oven wires.
So if max amp load on timer is 16 amps, then it is safe to add light bulb wire without line fuse between timer and light.
http://waterheatertimer.org/Fuseholder.html
4) Add comment and say what you are doing.
Posted on Jan 22, 2013
3 Suggested Answers
SOURCE: I use Omron H3CR 8pin
I don't have exact schematic for your 8-pin timer.
Use multimeter read ohms and voltage from pin socket to pin socket.
Use multimeter set to ohms to read continuity of pins on timer.
Pin timer relays have NO NC pins.
Some pins are Normally Open (no current flows until timer turns on)
The other pins are Normally Closed (current flows until timer turns on, and when timer turns on, this circuit turns off)
Posted on Apr 08, 2011
SOURCE: timer pins for start-stop don't start or stop the lights
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
Diehl Timer 4 pin wiring
well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Oct 15, 2008 | Dryers
11 PIN OMRON H3CR-A TIMER CIRCUIT
i found a wiring diagram using google search term h3cr-a use images tab 11 is a common 8 is nc 9 is no
Oct 15, 2013 | Hardware & Accessories
Need to know simple wiring where power output pins are on eagle signal control off-delay timer #81Q2A605
1) Copy following link for general pin timer wiring:
2) Eagle tech support:
http://www.danaherspecialtyproducts.com/Eagle_Signal/Service_and_Support/Customer_Service___Tech_Support/
3) Fixya appears on 1st page of google search for this product, indicates there is no clear information available on the web.
4) Add a comment and describe the wiring diagram that appears on side of device.
Each pin timer has wiring diagram.
The image I found shows 11-pin base, and push button or impulse input connects to terminals 2 and 6. Image is not clear enough to determine more information.
Feb 20, 2013 | Hardware & Accessories
Omron H3ca
Delay timers usually start with a push button, or momentary impulse of power. The delay begins when the impulse power ends.
H3CR-A is solid state multi-functional pin timer available in 8-pin and 11-pin models.
11 pin has six modes, and 8 pin has 4 modes
http://waterheatertimer.org/pdf/OMRON_H3CR-multi-function-analog-sell-sheet.pdf
How many pins do you have?
What exactly are you controlling with the timer?
And what function are you using?
Sep 04, 2012 | Omron H3CA-A Multifunction Digital Timer
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I use Omron H3CR 8pin to my CCTV in my car. I use pin 2 for ground,pin 7 for ignition, pin 4&5 for direct current from battery and pin 8 to +ve CCTV. My problem is when I off the engine the timer is...
Apr 08, 2011 | Omron Healthcare Omron H3cr-a-ac100-240v...
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
Hardware & Accessories Logo
218 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
