Question about Sunbeam Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te
The shaving blades came loose and fell off my sunbeam shaver, how do i put them back on?
    Problem Solver:
  • 10 Answers
Make sure the clippers are running.
Make sure the hinge (the bit you put the blade on) is open, if it is not, prize it open with a flat head screwdriver.
With the hinge open and facing you, slide the blade on the hinge with the blade number/size facing you. Snap the hinge shut.
Posted on Aug 03, 2010
Need a replacement blade
got the Manuel? order 1?! or enter OSP ELECTRIC SHAVED ICE HAWAIIAN in the question bar in goggle or i.e. LOL.
Mar 18, 2014 | OSP Electric Hawaiian Shaved Ice Shaver...
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
Feb 06, 2013 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at See link below
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
Sounds like one of the heads are damaged or something is not put together correctly causing it to jam. Watch the video below to make sure that you have the heads in correctly.
If you have everything in correctly and it stll jams, one of the heads is likely damaged. You can remove them individually and turn the blade clockwise inside the comb with your fingers. Each should turn freely. If any will not turn, you will need to replace them. You will find replacements for 7300 series shavers at See link below
May 04, 2011 | Philips Philishave Cool Skin HQ6760/HQ...
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Braun 8585 series
I found that the hole that the blade slots into had become worn and the blade was wobbling about too much under the foil. To solve it I wrap a small piece of masking tape around the metal shaft that slots into the hole and then push the blade back firmly into the slot. This seems to result in the blade pushing more firmly against the underside of the foil and giving a shave like new again.
Oct 10, 2008 | Braun 8585 Electric Shaver
Fallen apart shaver
This has happened to me several times. You just slip the metal tab sticking out of the blade assembly ( the flip up part} back in the slot until it snaps in to place.
Sep 06, 2006 | Norelco SmartTouch 9160XL Electric Shaver
Sunbeam Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te Logo
179 people viewed this question
Top Sunbeam Health & Beauty Experts
Kevin Hill
Level 1 Expert
Level 1 Expert
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
