Question about Goodman CLQ36AR49 Air Conditioner
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
(New goodman 3 ton gas package unit) I Replaced the board in the unit, I have the same problem with the new board as I did with the original board, the unit will not stop running.I unplugged the thermostat wires in the unit and wire caped I then plugged in the disconnect. The unit starts right up in adition to that my led light is blank I cant see having two bad boards any sugestions I am having the same problem with my fathers two and a half ton gas package unit. After two new boards, after a heating cycle the combustion exhaust fan and circulating fans continue to run. Everything in it has been tested and checks out, but those two fans are still running.
  • local24801 Jan 30, 2009
    The loop has been checked, the thermostat wires have been checked. Two new boards in it and after a heat cycle with the gas burner the combustion motor and circulating fan continues to run. After it is turning the burner off it blows the board fuse. Two servicemen along with myself have worked on this unit and it still runs. As soon as you put the disconnect in the combustion motor kicks in and does not shut off.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description, it would appear that the contacts of the switching relay are burned and have fused together. This would then make what ever the relay(s) are controlling switch on soon as plugged to the mains. Should this hold true, then it would be immaterial whether the thermostat is working or not or even for that matter wired to the system or not.
In some designs, the relays are on the printed circuit board of the controller while in some, it would be separate/external. Some designs also place a capacitor across the relay contacts to prevent arcing. Should the capacitor be faulty/shorted, it would exhibit the same, it would act as if the relay is engaged.
Would it be possible for you to post the wiring diagram if one is available?
Pls post back updates. Good luck and kind regards.
Posted on Feb 01, 2009
    Top Expert:
  • Goodman Master
  • 77,932 Answers
Have u tested the gas valve?
Posted on Jan 30, 2009
  • 326 Answers
Its the problem of the connecting switch which does not stop the powering .replace the power switch
Posted on Jan 27, 2009
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Goodman package unit will not. Come on in heat
sounds like a defective thermostat. try a replacement.
Jan 23, 2013 | Goodman Manufacturing GPG1342090M41...
Lowvoltage fuse keeps blowing
the contactor on the condensor if it blows on a call for cool.
Nov 27, 2012 | Gibson Nordyne GR6GD-X24K045C 2 Ton 13...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
My father has an older model two and a half ton goodman gas package unit. it has had two boards put in it, the problem is that the unit will go through a heat cycle and the combustion motor and the...
the fan induction motor produces a vacuum, check of orofice on motor is plugged by pulling hose off switch end and putting in mouth while running and sucking, this will make a whining sound immediately if no restriction. the fans are controlled through the board by vac., swich, limit sitches, and timers in the board itself. maybe a bad ground on flame sensor.
Jan 29, 2009 | Heating & Cooling
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
22 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
