Question about Samsung DV220AEW Dryer
Dryer isnt getting hot
Dryer runs well just doesnt get hot on any cycle
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Posted on Jan 22, 2013
Why does the outside of my dryer get so hot? Also, why does it not stop running when i open the door? I have to turn the cycle off and then open the door,
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 08, 2011 | Kenmore Dryers
Dryer got extremley hot and now doesnt turn on
heatman101
May 13, 2011 | Kenmore 600 6965 Electric Dryer
It doesnt want to blow hot air
It could be several things the heating element , thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at http://appliancehelponline.com/edryerelementvideo.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles. This tutorial should be very similar to your model
http://appliancehelponline.com/electricdryertroubleshoot.html
Jun 07, 2010 | Frigidaire Electric Dryer
It well not dry clothes
The dryer gos through its cycle and doesnt get hot
Jan 20, 2010 | Kenmore Dryers
My maytag electric dryer is not getting hot.
It sounds like the element shorted out and caused more damage to the unit. Remove and check the heating elment, thermal fuse (located near element), and timer. The timer will be hard to test if you don't have a meter. I would suggest that you check the element first. This is probably your main problem.
Apr 18, 2009 | Dryers
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryer isnt drying on frist cycle
This is most likely an element problem. it is best that a tech replace it but if you feel comfortable take it out and to your local repair shop. match it up and reinstall it.
good luck
Jason
Jan 19, 2009 | Roper Dryers
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Bosch dryer
I had this problem for an axxis condensation WTL5410.
When starting dryer ligghts on front would cycle through normally as if dryer were running but dryer would not turn or get hot.
The problem was the door switch.  Push in the door switch activator on the bottom right of the dryer.  Push it hard a few times and try the dyer again.
doesnt sound like a great solution - but after 150$ and 2 service calls - it was what fixed it for us.
Jan 14, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Samsung DV220AEW Dryer Logo
128 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
