Question about Maytag Atlantis MDE7400AY Electric Dryer
Loud thumping noise
As soon as I turn on the dryer I hear a VERY loud thumping noise. Wondering if there is a problem with the drum?
  • jwm_1998 Jan 29, 2009
    The exhaust fan was the problem. It had missing and broken fins which was throwing the motor out of balance. Thank you for your responses.
Remove the top of the dryer and check all the screws on the drum. One of the screws had backed out and was strking that top and sides of the dryer. Tightened it up and works great.
Posted on Jan 29, 2009
  • 65 Answers
IT COULD BE THE DRUM BUT I WOULD INSPECT THE DRUM ROLLERS TO SEE IF ONE HAS A FLAT SPOT IN IT. IT MIGHT NOT HURT TO CHECK THE DRUM BAFFLES/PADDLES TO MAKE SURE THEY ARE TIGHT.
Posted on Jan 27, 2009
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud thumping noise
a roller under the drum has a flat spot
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Loud thumping noise has resulted in penny size hole in the drum.
Check your owner manual some LG had life time warranty on there drums..if so call for service..
Sep 21, 2009 | LG DLE3777 Electric Dryer
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Dryer
HI thanks for your question. the noise you hear , is worn drum rollers or back bearings and front bearings. if you need more assistance get back to me .
Oct 11, 2008 | Estate TEDX640JQ Electric Dryer
Dryer make very loud thumping noise when running
HI THANKS FOR THE QUESTION. ON, DRYERS THEY USE DRUM ROLLER'S SO THAT THE DRUM TURNS EASY. THE NOISE YOU ARE HEARING IS THE WORN DRUM ROLLERS REPLACE THEM. THANKS THE APPLIANCE DOC.
Oct 04, 2008 | Amana Dryers
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
225 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
