Question about Saws
The blade will not stay on a d28770 portable band saw
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
clyde2j2
  • 137 Answers
SOURCE: help with my dw100 band saw
Pull the plug on the saw, take off the covers on the upper and lower wheels of the saw.
You will see an adjustment bolt above the upper wheel and below the lower wheel, with the band saw in place on both wheels turn the upper wheel by hand, if the band saw moves to either side of the wheel use the adjustment bolts to center the band saw.
Posted on Jan 30, 2009
  • 360 Answers
SOURCE: band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Posted on Mar 31, 2009
Editor925
  • 285 Answers
SOURCE: band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Posted on Apr 18, 2009
I need to replace the gear oil in a Dewalt D28770 portable band saw. what type of oil do I use
I suggest you buy the gear oil from Enco. And buy blades on sawblade.com
May 25, 2014 | Saws
Blade drift with Milwaukee bandsaw
Worn band saw guides maybe? Or too much tension or change the blade , I use bi metal Haltbar band saw blades of sawblade.com
Mar 26, 2014 | Milwaukee 6238 Deep Cut Portable Band Saw...
How do you align the wheels
I don't own a speed band saw. But recently, I fixed my band saw due to wheel alignment issue. I just read this blog .
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
Blade walks off the drive wheels
If the blade is walking off the wheels, the wheels are out of alignment with each other. This can be caused by loose screws that hold wheels on their pulley shaft, a worn or lose pulley shaft, worn or broken bearings, ect. Anything that holds or supports the wheels can be lose or worn to the point the wheels are out of alignment which affects the tracking of the blade.
D28770 dewalt bandsaw derails blade
Over-tensioning the blade can and does cause the blade to "crawl" off.
Jan 26, 2009 | Saws
Blade keeps derailing
I am not sure why you took the guides off in the first place,   That is definitely related to the problem but is it possible that taking those guides off created a deeper problem?
Jan 26, 2009 | Dewalt Saws
D28770 blade keeps derailing
I need to order a new tire for 12 in. jet bandsaw but i can,t find a place to order one
Jan 23, 2009 | Saws
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Saws Logo
44 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
