Question about Dishwashers
No water goin in dishwasher - Dishwashers
  • Dishwashers Master
  • 3,111 Answers
Check to see if the water is in the hose that goes to the bottom of the dishwasher.
That hose attaches to an electrical switch at the bottom and the back of the machine underneath.
That switch controls the water flow into the machine, it has two wires coming from the timer.
It is often blue in color, and also has a smaller (black?) hose going up to the machine itself.
The switch may not be working, and need replacement.
Also, be sure the electric wires are telling the switch to function,or suspect the timer.
Be blessed.
Posted on Jan 21, 2013
Kenmore dishwasher, motor runnig no wter in dishwasher
You can test the fill valve by reading ohms it should be between 750 and 1200 ohms if it's in that range turn knob to the drain cycle and see if the wires goin to the drain valve are putting out if not that the wires should have 5130 ohms if not it's the timer
Mar 23, 2014 | GE PDW1800NBB 18 In. Built-In Dishwasher
GE dishwasher model# GSD1821X66BB tower is not spinning during cycle?
Not enough water pressure there is a clog somewhere or the pump is goin out
Sep 28, 2013 | GE Dishwashers
Water goin in to the engine
Blown head gasket. Or worse, cracked head or engine block.
Oct 15, 2012 | 1990 Toyota Cressida
Hi I have a bosch classix maxi been great for the last couple of years but it has failed for the first time yesterday. The dishwasher did not start it just kept making a groaning noise and would not start...
Completely unplug the dishwasher and leave disconnected for at least 10 mins.
Also be sure to check the drain pipe is not kinked or obstructed and that the filter is also clean and empty
May 04, 2011 | Bosch 24 in. SGS43C12 Classixx...
The dishwasher is not cleaning properly only cold water goin through no hot
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 27, 2011 | Beko 24 in. D3421F Free-standing...
Ive got no water goin into dishwasher,water is tryin to,but cannot
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Jan 19, 2011 | Whirlpool Dishwashers
Nearly every time is disintegrating and crumbling off with rust
ur goin to have to make the choice but usually when the rackes are getting rusty its had a good long life and prolly should get a new dishwasher
Oct 31, 2009 | Frigidaire FDB658RA Built-in Dishwasher
Dishwasher leavin something on dishes after washes
gritty ? This can be either the poweder or detergent you are using.Cheap HOME BRAND type. Other than that it is possibly hard water buildup where calcium is now being baked on the dishes in the drying mode.
Try using a Dishwaher Cleaning package by FINISH to see if this helps it
Aug 01, 2009 | MSI 865PE Neo2-V Motherboard
Water is not goin into the dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jul 21, 2009 | Dishwashers
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
