Question about Belkin (F6D3230-4) Router (F6D32304)
Installing Belkin Wireless G Router F5D7230uk4
When I load the Installation CD, its suppose to give me "RUN THE EASY INSTALL WIZARD", but this option does not appear, I'm only getting a "VEIW MANUAL FOR ROUTER" option, and I am unable 2 install the router?
Will this solutiuon work in the UK. I tried to use your advice above as I am having a similar problem, however when I search the ip address in my internet browser it said it was taking too long to load and my 'net gave up waiting for it to respond.
I have applied my whole query on this website. If it helps, have a look at it all. I have put the link below for you :-) any advice would be great! Cheers!
http://www.fixya.com/support/t291472-belkin_installation_cd_wont_install_any
Posted on Dec 10, 2007
  • 32 Answers
No. Forget the CD and plug a computer directly into the wireless router with a ethernet cable. Open your browser and type 192.168.1.1 When a username/password box pops up type admin for username and password for the password. It should log you into the router. From there you can configure the router to detect and list your devices properly. Normally the router should be working out of the box. If admin/password doesn't work try admin/admin or admin without a password. Anymore questions with this, post here so I can help.
Posted on Jul 19, 2007
6ya staff
SOURCE:
Lost install CD
You may install the Router manually. The installation CD is just a wizard that will guide you with the set up. Or better, go to this website and find your device to get an assistance.
http://en-us-support.belkin.com/
Setting up a router is pretty easy, just take note and understand how it works!
Jun 20, 2011 | Belkin Basic Wireless Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I have lost my cd to install for my belkin router what shall i do ?
Hi i got your issue
no problem if you lost the installion Cd
Step 1: Contact belkin customer support 18002235546 and select IVR option 5 4 2....they will give You a free cd
Step 2: Or contact belkin technical support 18002235546 and they will assist in installing the router witout the cd
Thank you:
Priya
Oct 02, 2010 | Belkin Wireless-G Plus MIMO Router
My install wizard cd rom no longer works, can i get it online?
There is an easy install wizard download here on Belkin's web site.
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5096&scid=0
Jul 09, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Can someone send me the link to download complete installation CD for Belkin G router F5D9230-4 ? - Jeet.
Here's the firmware and easy install wizard
http://www.belkin.com/support/search/?q=F5D9230-4&atp=11
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant load drivers
yes download the firware from the webstie of the belkin of your router then upload it in the router that's it you know about the router default ip address go for it if you not get it in the box is wittiern default ip address ok
Mar 28, 2009 | Belkin (F5D6230-3) Wireless Router
I have a belkin wireless router but lost the cd to it
I have the CD that comes with this wireless router. I was having the same problem too and once I ran the eazy install wizard it took care of all my problems. I just don't know how to share this installation wizard with all of you through this website, if you could let me know I would be more than glad to send it your way. Email me at [email protected]
Feb 18, 2009 | Belkin (F5D7230-4) Router (587009)
Installation software
Don't worry the router does not have a driver. Just run the network wizard in windows. And set up a new connection you will see.
Oct 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin Installation CD wont install any software for my wireless router
click on the start button, all programs then go to accessories and then the program compatability wizard see if it will run from there if not try start, run then click browse then on the right hand side my computer, then click on the cd drive then the setup one of these should work
Dec 10, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Belkin (F6D3230-4) Router (F6D32304) Logo
1,554 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
