Th-50pe8u power on led blinks 7 times with a blank screen
    Genius:
  • 1,003 Answers
Replace the mainboard
Posted on Jan 21, 2013
  • 138 Answers
SOURCE: Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Posted on Aug 20, 2008
roety
  • 585 Answers
SOURCE: Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Posted on Aug 17, 2009
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
SOURCE: Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
I have a Panasonic th-c50fd18 plasma TV. It shows a blank screen when turn on, blinks two times every 5 to 8 seconds. computer board, if so what is the model #?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Panasonic Televison & Video
Hi, I have a Panasonic Viera TH-P42S10A, when I turn on at the power switch, wants to start up but blank screen and LED light flashes 5 times, Help!
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 29, 2015 | Panasonic Televison & Video
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 01, 2014 | Panasonic VIERA Televison & Video
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
TV will not turn on. Power light blinks 7 times, then pauses, blinks 7 times again. What could the problem be?
If you are a DIY then you will need to try to unplug the SD board and reconnect and try again, if it stills shutdown with 7 blinks then the SD board is bad and maybe the
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Jan 11, 2011 | Panasonic TH-37PX50U 37 in. HD-Ready...
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Jan 08, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
