Question about Pool & Spa
Raypak Pool heater corroding pilot assemblies at alarming rate
Is it a likely issue or just simply time to trash and replace
  • 1,631 Answers
It must be raining inside your heater. Either your water flow (gpm) gallons per minute is off, or your gas pressure could be off. If ether one of these is not proper, then you could have a high condensation possibility inside your heater and the combination of heat and moisture will rust out/corrode your pilot assembly's quick.
Posted on Jan 22, 2013
SOURCE: I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Posted on Sep 09, 2009
  • 246 Answers
SOURCE: Pool heater pilot works but no heater
make sure filter is clean, make sure filter is at 10-18 psi , also post if electronic or millivolt heater
Posted on Sep 14, 2009
  • 990 Answers
SOURCE: The heater does absolutely nothing when you turn
Unless there is water running out of the inside it is always repairable. You can start by pulling the burner tray and cleaning the unit and the burners. Also pull the wires and clean the leads and contacts. At 23 the heater is probally a milivolt run heater so a small drop in power can stop the heater from working. Often the problem will be the pilot generator or the gas valve. The generator should delevop 1/2 a volt to run the heater. This can be measured with a milivolt meter. You should get 500-700mv from the generator. If you get that and have no pilot you may need a gas valve and if not you probally need a new pilot generator and it would be best to replace the whole pilot assembly. If you live in Calif. or someplace that makes standing pilot obsolet you can probally find these parts on line through Ray-Pak.
But before starting check the filter to be sure it's clean. If you have had the pool for 23 years that goes without saying but I have to say it anyway.
After that you can use a jump wire and isolate each itim in the saftey circut (thermostat, high limits, presure switch...) just follow the wire when it leaves the gas valve and follow it to each item and jump across. If you find one of these itims to be the culpret it is just a simptom and their is probally another problem and the part just keeps the heater from working so as to keep it safe from that problem. Good luck and let me know what you find and we can go further if need be.
Posted on Mar 13, 2010
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
StepehnD
  • 78 Answers
SOURCE: service code ROL
This indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Posted on Jun 19, 2010
Heater is corroding pilots at an alarming rate..........1 per week....is there a potential fix or is it time to replace
check for leak in heat exchange if ok then if water is under 70 degrees it will condense and rain down on the pilot generator
Jan 21, 2013 | Raypak 2100 Pool Heater Gas 266000 BTU'...
Raypak RP2100 Pool Heater
check gas pressure if too low this will happen
May 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How to replace a pilot
Probably no need to replace pilot. Just clean it. If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 21, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have a Raypak RP2100. When I turn it on the pilot lights fine but after a few minutes (~30 minutes) the heater turns off and PLT is indicated on the control panel. If I recycle the power it lights fine and...
Aug 01, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gas pool heater pilot will not stay lit
Depending on the make and model of your heater, the first thing I would check for is gas pressure. If it is sufficient, check the pilot assembly for corrosion and/or a damaged pilot tube. Sometimes replacing the entire pilot assembly is a sure fix and also replaces the pilot generator that degrades over time. A new pilot assembly takes care of a couple of problems by improving gas flow and millivolts generated. Also, the orifice inside the pilot assembly could be corroded or clogged.
Jun 15, 2009 | Hayward H Series Pool & Spa Heater 400k...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Pool & Spa Logo
44 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
