Question about Whirlpool Dryers
Dryer not drying
Have a whirlpool gas dryer Model # 1cwgd5850w0 that takes way too long to get the clothes dry., looked at a site that said to put meter on the fuse and it shows good., any ideas ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Check the air vents both the inlet and outlet sides of the fan. Make sure there are no obstructions on the exhaust side all the way to the outside of the home.
Posted on Jan 22, 2013
Lumpy816
  • 246 Answers
SOURCE: Whirlpool Electronic Gas Dryer
I would suggest cleaning your moisture sensors. If you stick your head inside the open door and look straight back towards your lint screen, you will see 2 silver bars. These are your moisture sensors. They can get a coating on them over time. Once this occours, the moisture can't reach the sensor and the machine thinks the load is dry and shuts down. Using the abrasive side of a sponge or even some fine grit sand paper, run it back and forth each of them. You should be good to go if you've already cleaned the area underneath the lint screen, made sure the hose from the dryer to the wall is not kinked, folded over or smashed and you have good airflow coming to the outside of the building.
Posted on Jun 19, 2008
rickzilla
  • 706 Answers
SOURCE: Gas dryer not completely drying clothes
Hello br4noles,
based on your description, you may have one of several problems but the prime suspect would be a restrictive exhaust system. Check and make sure you don't have a blockage in your vent system all the way from the dryer to the exit point. When cycling, you should have a fairly robust air flow at the exit outside. If you don't, then you may have a blockage in your vent, something restricting the blower from operating at 100% or lastly a poor flame from your gas system. Air movement is the key thou so I would focus on that since you didn't state that the dryer wasn't heating up.
Regards,
Rick
Posted on Nov 25, 2008
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
localwonder
  • 6784 Answers
SOURCE: Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Posted on Jul 31, 2009
daddy1264
  • 76 Answers
SOURCE: gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Posted on Sep 16, 2009
Testimonial: "thank you "
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
Whirlpool dryer model #GEW9250PT1 not drying properly
when was the last time you cleaned your dryer?all a dryer does is move air around and if it can't cycle through the dryer the clothes won't dry. unplug the dryer and then you need to clean the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line,if the vent line is a long run from the back of dryer to the outside vent i use a leaf blower to clean it out,make sure the outside vent is clear first then blow it out,if it's a short run vac it out,most problems start just from lint buildup,the clothes don't dry the dryer runs hot and parts start messin up,also vac out under your fridge,take the bottom kick plate off and vac it out,you can kill the compreesor if you don't,good luck
Apr 05, 2010 | Whirlpool Dryers
LGR5636kq0 model. not drying clothes reasonable time
It could be the tumbler. Also check the vent coming from the back of the dryer (make sure it is not clogged)
Nov 10, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Feb 11, 2009 | Whirlpool LEQ8611L Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
