Question about Compaq nl284la - Presario Cq40-320la Notebook Pc
Bootmgr is compressed - Compaq nl284la - Presario Cq40-320la Notebook Pc
  • Compaq Master
  • 27,725 Answers
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Posted on Jan 21, 2013
What happen when pc says bootmgr is compressed?
if you have the OS disk you can use that and fix windows bootmgr.
Mar 09, 2015 | Microsoft Computers & Internet
Bootmgr compressed self fix
At times after enabling / disabling disk compression on Win 7 or Vista boot drive you may receive the Bootmgr is Compressed error upon restarting your computer as displayed below:
BOOTMGR IS COMPRESSED
Press Ctrl+Alt+Delete to Restart
1. After rebooting with OS DVD, choose "Repair your Computer" and then select "Startup Repair". Reboot your computer.
2. After rebooting, click on "Load drivers" button an explorer style window will pop up, go ahead and right click on the drive that may have been compressed and deselect `Compress this Drive'. Choose apply and then apply to subfolders/files before rebooting.
There are registry commands also that can be used. But the above 2 steps can be very helpful to start with.
Jan 24, 2014 | Acer Computers & Internet
Bootmgr compressed
Check this discussion out - specifically moti68's comments. Good luck!
http://www.howtogeek.com/forum/topic/bootmgr-is-compressed
Jan 15, 2013 | Dell Mini 910 Netbook
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
BOOTMGR IS COMPRESSED SAYS TO CTRL+ALT+DEL TO RESTART BUT DOESN'T
YOUR HDD IS BAD.IT SEEMS BAD SECTORS.TRY TO REINSTALL THE OS.I RECOMMEND TO BUY A NEW HDD AND INSTALL A NEW OS
Apr 11, 2012 | Toshiba Satellite R15-S829 Laptop...
After the msg is displayed,
Press Ctrl+Alt+Del to continue Try to boot via the Bootable disc, boot to safe mode via the disc and try the folowing
go to dos and try
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
If the above process doesnt works then try,
"Click 'Repair my Computer'
At the prompt to select your OS installation, click the button that says 'Load Drivers'. This should bring up a explorer-style drive browser.
Then just right-click on the drive you tried to compress, and deselect 'Compress this Drive', which should still be ticked on. Hit apply, and apply to subfolders/files.
May 08, 2011 | HP Mini 1000 Netbook
When pc boots it says bootmgr is compressed and does not boot
Boot using the Vista DVD or the respective OS Disc and use the "Repair Option" or go the next step.
Boot using the Vista DVD or the respective OS disc. Go to the Command Prompt. then type the following.
expand bootmgr temp
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h.
This should Work.
Oct 25, 2010 | Computers & Internet
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart in Windows Vista Home Premium
BOOTMGR is Compressed
http://img.roxio.com/enu/support/products/backontrack/resolving-bootmgr-error.pdf
follow the steps on the above link and resolve the issue..
It will surely work..
The link is very very helpfull
May 17, 2010 | HP Pavilion dv5170us Notebook
Bootmgr missing
When I turn on the computer...
I get a message " Bootmgr is compressed"
and to press CTR (t) ALT (t)
and when I do, the screen returns to the
top message: Bootmgr is compressed.
If I can, what do I need to do
to get to my desk top?
Dec 28, 2008 | Toshiba Satellite A135-S2276 Notebook
Hard drive compressed/bootmgr compressed
I'm assuming that you are running vista. Try one of the following:
You will require a Vista DVD to boot off of.
Proceed to the System Repair Option, and follow the steps. It should repair your boot sectors..
Or
Once you have booted up, Press SHIFT+F10 to run 'cmd' prompt.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
Sep 16, 2008 | Computers & Internet
Compaq nl284la - Presario Cq40-320la Notebook Pc Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
