Question about Whirlpool Microwave Ovens
How do i correct the clock time on whirlpool microwave MW0609?
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How to set the clock on this ,Opel whirlpool microwave
Usually one presses the control panel Off/Reset button, presses the clock button, enters the time (eg. 710 for 7:10) and presses the clock button again.
Jun 13, 2015 | Whirlpool Microwave Ovens
Whirlpool microwave
    • 1 Press the "Clock Set/Start" or "Clock" button on the control panel.
    • 2 Enter the time of day using the number pad, or use the "+" and "-" buttons to scroll to the correct time.
    • 3 Press the "Clock Set/Start" or "Clock" button once again to save the time.
Apr 11, 2012 | Microwave Ovens
Set the clock on my microwave
Usually just push the clock button the time nd then either the clock button again or the start button
Feb 01, 2012 | Whirlpool Max 14 Microwave Oven
Hi we have a Whirlpool X2-20ES microwave oven How can I set the clock (day time)? Thanking in advance Sid
1. Press CLOCK
2. Press STOP
3. Press number keys with correct time (123 = 1:23)
4. Press CLOCK again
Jan 28, 2011 | Whirlpool Microwave Ovens
Whirpool microwave resetting clock
Whirlpool Microwave X2-30ES
I was pressing one too many buttons.
Press Clock, then Stop, press in the 24 hour time digits, then press Clock again.
Nov 02, 2009 | Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Nov 04, 2007 | Bosch HMB402 Microwave Oven
Welbilt microwave
You can try different combinations (where # is the number need for correct time) such as: 1. CLOCK 2. # # # # 3. CLOCK 1. CLOCK 2. # # # # 3. START 1. # # # 2. CLOCK Otherwise, if you could submit a photo of your control panel, we might be able to pinpoint it for you.
Mar 04, 2007 | Welbilt MR95TW Microwave Oven
Whirlpool MT4155SPS
If you mean by "races" that the coooking time goes way too fast, then you may just need to reset the microwave. This is usually done by unplugging the microwave for several minutes then plugging it back in. You can also visit http://www.whirpool.com or call 1-866-698-2538 to speak with customer service. If that doesn't fix it, chances are that the integrated circuit (chip) is corrupted. Whirlpool doesn't make the chips available, so the whole control board (they may call it the "clock") would need to be replaced. If the time count sems correct, it's also possible that a sensor is bad, or maybe yopu have a bad door switch. You can do a Yahoo search for my file "doorsw.txt" to help you with the safety tips and disgnosis of door switch problems.
Oct 29, 2006 | Whirlpool MH6150XLS Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
