Question about Lexmark X5150 All-In-One InkJet Printer
On some lines the letters are cut in half and not lined up
Printer problem
When I print some of the lines have letters that are cut in half and not lined up. Can you help?
    Genius:
  • 2,035 Answers
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Jan 27, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
Last line cut off
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Dec 01, 2009 | HP Photosmart C7280 Printer
The top half of letters on certain lines of print are offset by about half a letter space from the bottm half of the letters. Usually but not always the same lines. help please
This usually indicates a need for a new print cartridge or the printer head is dirty. You can run the automatic printer cleaning utilities. Note: do them several times.
Also, if you are a little handy, use Qtips and rubbing alcohol and clean the print head.
Sep 18, 2009 | Epson LQ-590 Matrix Printer
Bottom of letters in document not printing.
it is problem your printer page setup please set defalt or re install printer driver
thanks
xptareq
Jul 30, 2009 | HP Photosmart C4180 All-In-One InkJet...
Prints complete lines with occasional lines half height of letter
Your printer cogs may be damaged or your paper rollers could be slipping resulting in this "odd" output.
Paper rollers can be cleaned with an appropriate cleaning kit but if the cogs are damaged it's not worth repairing.
Jan 22, 2009 | Epson Stylus CX6600 All-In-One InkJet...
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
HP 5740 Printer skips top half of several lines
try a letter with brown letters to see if it is the black ink cartridge Refilled cartridges do that from time to time
Sep 12, 2008 | HP DeskJet 5740 InkJet Photo Printer
Tops of characters cut off
Go to www.fixyourownprinter.com for expert help on this particular problem
Jul 12, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Lexmark X5150 All-In-One InkJet Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
