Question about Pioneer Kuro KRL-32V 32 in. LCD TV
Sometimes, when you leave them flashing, the blue (ON) indicator comes on and the TV is okay. The problem only appears when you leave the tv a while in the OFF position (cooling down?)
Replace the power supply!
Posted on Jan 21, 2013
Testimonial: "That was indeed the problem! Thanks for the help."
SOURCE: Pioneer Elite Plasma TV
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
Posted on Sep 20, 2008
SOURCE: TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Posted on Jan 28, 2009
SOURCE: pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
Posted on Mar 29, 2009
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
SOURCE: Pioneer TV External Tuner Problem
As you all know this is a very common problem. It is located in the two power boards inside the machine. These media receivers run really hot and the solder on these circuits boards crack, thus losing power when hot. Leave to cool and ok again. To fix you can remove these boards and touch each solder joint with a fine tip soldering iron until it becomes molten then move on to the next joint. Do all the joints, reassemble and presto, you should be back in business. These board are located between the on-off swith and the rear power input. It is a little fiddely, but if you halfway competant, then it shouldn't be a problem. I've done it a couple of times now, so if anybody feels a bit nervous, I'll do it for them for a small fee. contact glangford@tycoint.com
Posted on Jan 14, 2010
Oct 14, 2015 | Pioneer Televison & Video
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Dec 02, 2011 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Oct 20, 2011 | Pioneer Kuro KRL-32V 32 in. LCD TV
Apr 13, 2011 | Pioneer Kuro KRL-32V 32 in. LCD TV
Dec 31, 2009 | Televison & Video
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
Sep 27, 2008 | Thomson 24WK25U 24" TV
Jun 10, 2008 | Televison & Video
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Sep 01, 2013 | Pioneer Kuro KRL-32V 32 in. LCD TV
510 people viewed this question
