Question about Canon iR 2016i Black and White Copier
I have a Canon ir2010. it has stoipped printing from my computer. when i press system i see trap 00000000 on the display. any idea how to fix.
The printer was working fine up to a couple days ago. I disconnected and reconnected all cables. no luck
SOURCE: canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Posted on Nov 12, 2008
  • 10 Answers
SOURCE: I have a Canon MP370
yaa thats your black Print Head is not working, you need to get it replaced by new print head.
thats only solution.
Posted on Feb 27, 2009
  • 71 Answers
SOURCE: canon ir2010 marca error.00000000 no imprime
Error 0000000 is the fixing unit, need to replace.
Posted on Jan 02, 2011
shawn38
  • 200 Answers
SOURCE: The first print attempt after booting my computer
I would suggest downloading the current print driver from Canon's website for your machine and see if that corrects the problem.
I hope this is helpful,
Shawn
Posted on Jan 29, 2011
  • 70 Answers
SOURCE: B200 error Canon Mp540
B200 is print head overheating error. Find details here:
Canon E200
Posted on Sep 30, 2011
I REALLY NEED SOMEBODY TO TELL ME WHATS AN E000 IS
You need to formulate your post into a sentence that makes some sort of sense instead of a cryptic error code. You know something like
"I have a Canon MG7120 al in one printer. I was printing, it stopped printing and the display shows E000. Can you tell me what the error is and how to fix it please"?
WHAT DOES SYSTEM ERROR E000 MEAN? - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting
  1. Cached
The error is a system fault error that can sometimes be reset: Follow these steps to reset the error: Press Additional Functions key. Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. Ask Your Own Printers Question ...
I have an MF4350d. It is showing SYSTEM ERROR E000. What does ...
  1. Cached
I have an MF4350d. It is showing SYSTEM ERROR E000. What does that mean and what do I need to do? Thanks! - Answered by a verified Technician.
Technology Time: Canon Error E000, E001,E002, E003, E007
www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
  1. Cached
  2. Similar
I described in a previous post that E000, E001, E002, E003 and E007 are fixing unit temperature error codes. Lets go into more detail now. .... I have A problem canon 2002 when i power on the machine then show error E002-0000 pls advice me what i do ? ReplyDelete ยท Lizpeth G. ... What's prize of cannon copier E354?
Mar 08, 2018 | Office Equipment & Supplies
My Canon 2010f in error 0000
I found this for you.
I can clear error code e000 of ir2010
press *function and # and arrow to #7 press ok and #4 printer reset press ok
May 09, 2015 | Canon Office Equipment & Supplies
What is the problem of error code 000013-0000
Thanks a lot , i can clear error code e000 of ir2010 by your solution ,I press *function and # and arrow to #7 press ok and #4 printer reset press ok
Dec 17, 2013 | Canon imageRUNNER 2010F Copier
My tally 4347 i08 powers on, but stays in the initialization loop. it displays hdw trap, and restarts initialization. how can we stop this
If the 4347-i08 is connected to a computer system when it displays the HDW TRAP error when powered on I would recommend disconnecting the printer from the computer system, then power the printer ON as a free standing printer. If the HDW Error is seen when you power the printer on when it is not connected to a computer system or print server, this indicates there may be a fault with the printer. I believe the "HDW TRAP" error is displayed due to an unhandled error in the printers firmware. There may be a number of causes for this error, if this error is seen when the printer is free standing and not connected to any computer system, It is worth checking the following; Check the print head is correctly seated in the printer and is free to move. Check the paper path to ensure there are no obstructions to paper motion. Check all electrical connections. Check for any thing which may cause a short circuit within the printer, ie loose wires, foreign bodies etc. Check the main logic board connects to the interconnect board and ther are no bent pins etc. If you continue to see the error when the printer is not connected to the computer system, it is likely the printer is relatively new as the model is relatively new therefore should be covered under a warranty in most classes, it may be best to contact your reseller or Dascom, the manufacturer directly. If the printer powers on ok free standing then this indicates there may be a connectivity or data format issue. Try printing a menu print on the printer to see if it is capable of printing. If the printer is connected via the parallel interface either directly to a terminal or to an external print server like a JetDirect, the problem may be caused by bi-directional communication disrupting the printer in an unexpected way. You can disable Bi-Dirctional communication, I believe this will be called Cx-Bid within the extended menu on the 4347. To change this setting; Power the printer on holding down the ONLINE button. When the printer finishes initialising release the ONLINE button Press the button order NEXT on the display (button 4) repeatedly until you see CX-BID on the top line of the display. Press the button under CX-BID to select the option Using button 2 or 3 change this setting to OFF Press button 1 under SET to save the setting. Cycle the power on the printer. On any external print server you may also need to set the parrallel interface to a Uni-Directional type. If the problem is only seen when print jobs are received from the system, check; The driver or device type selected on th host system Ensure the emulation selected on the printer matches the host system, and vice versa. Try printing a plane text file to the printer to see if this will print this will identify if a particular job is causing a disruption. If the printer is replacing a pre existing printer, ensure the menu setting on the 4347 are set up in the same way as the old printer. If the problems continue perhaps if you advise how the printer is connected and to what sort of system and when the error is seen I may be able to offer some additional suggestions. In the meantime I hope this is of some help.
Dec 14, 2011 | Tally Office Equipment & Supplies
Canon ir2010 marca error.00000000 no imprime
Nov 10, 2010 | Canon iR 2016i Black and White Copier
Canon ir2010 errorcode E000, hoe te verhelpen
the fixing assy that heat and sets the toner to the paper is faulty. it would have to be replaced as the element is broken
Oct 31, 2010 | Canon Office Equipment & Supplies
Error code E000
can u please check the fixing
Aug 03, 2009 | Canon imageRUNNER 2270 Copier
Canon i550 printer stoipped printing
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Hi ya have a canon ir2010 copier which prints but with a band of toner across the top of the page any ideas
Looks like a worn out or dirty drum unit. I believe you need a service center to replace this drum or service it.
Aug 19, 2008 | Canon Office Equipment & Supplies
Canon iR 2016i Black and White Copier Logo
old marine
old marine
