Question about Panasonic Mc-Ul594 Eco Max - Bagless Upright Cleaner
Manual for panasonic MC-UL594
Manual
Why doesn't brush roller rotate?
The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
Brush bar not turning. belt ok
hair carpet strand has to be removed from around brush head mounting location or motor,switch faulty
How to change the hepa filter
ours has a filter under the collection cup another smaller foam one in the hole above the motor(pulls out with a knife tip)..and a panel on the front that clips in place with a paper woven filter behind that cover..Ours must be an older version of yours.
Jan 11, 2014 | Panasonic Mc-Ul594 Eco Max - Bagless...
Changing hepa filter
Helen,
Remove the lid of the Dust Bin, and while holding it upside down in your hand, insert a philips screwdriver (this needs to be a medium screwdriver but with a long blade!) down through the centre of the actuating column. Hold the Filter Refresher knob (green) to prevent it from moving and undo the philips screw.The assembly will now come apart. Pull the actuating column out (the philips screw will remain in the column so don't loose it) The Filter Refresher knob will come away from the Lid. The Hepa Filter can now be removed and the replacement fitted. If the replacement filter is not supplied with a rubber gaskit use the gaskit from the old one..Re-assemble in reverse order.
The role bar at the front isn't spinning
HI ALL YOU NEED IS A NEW DRIVE BAND YOU CAN GET THEM FROM A AUCTION SITE
Nov 04, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Installing new belt
+>> Unplug the mains lead from electrical socket <<+
• Turn cleaner over in flat position.
• Release lower plate by rotating the 3 lower plate latches to the UNLOCK position.
• Remove lower plate and remove any dirt that may exist in belt area.
• Remove beater bar by gripping the belt side of the beater bar and carefully lifting it out.
• Remove worn or broken belt.
• Clean beater bar and the end caps.
• Loop new belt around motor shaft and beater bar belt groove.
• Reinstall the beater bar by inserting the end cap of the beater bar to the slots at both ends of th beater bar.
• After reinstalling the beater bar, turn it by hand to make sure that belt is not twisted or pinched and that all rotating parts turn freely.
• Reinstall lower plate by hooking front end of lower plate into slots on front of nozzle.
• Press lower plate onto nozzle and secure by rotating the 3 lower plate latches to the LOCK position.
Jan 12, 2013 | Panasonic Mc-Ul594 Eco Max - Bagless...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
Panasonic MC- UL594. do I change filter?
Hey, this is Tristan with Crucial Vacuum,
In order to change your filters, you must remove the canister from the vacuum. After, there's a "lift holding bracket" that you could pull to get the HEPA filter out. There you can access both pre-filter and HEPA filter to clean thoroughly!
Below I have attached a link to the users manual for the Miele S7210. You should refer to page 12 to view the diagrams pertaining to my suggestions.
http://dl.pdf-instructions.com/new/external_light.php?id=5389594&RDM=55587&brand=PANASONIC&ref=MC-UL594&real_ref=MC-UL594&real_ref_top=MC-UL594&langueM=&key=b1ea5812fd845c2d43fc1ef8a031bd01&security=d4f8a32c533aba48c416cc27d7653954&host=pdfretriever.com&errorURL=http%3A%2F%2Fpdfretriever.com%2Fframe_tempo_pdf.php%3FID%3D5389594%26lg%3DE%26src%3D15&n1=3866&n2=2853&res=4378&modeSC=M&direct=1
You can purchase replacement parts for Miele direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful! If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customercare representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Jun 15, 2012 | Vacuums
What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Dec 12, 2009 | Panasonic MC-V7380 Vacuum
Panasonic Mc-Ul594 Eco Max - Bagless Upright Cleaner Logo
59 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
