Keeps pausing and stopping during cycle - Washing Machines
It could be the belt , mine did that and it was the belt or it could be your hose that drains water and puts water into it might be clogged up .
Posted on Jan 21, 2013
aborcass
  • 2651 Answers
SOURCE: WASHER KEEPS STOPPING DURING CYCLE need to pause and restart x's
i would remove hte bottom access panel (3 screws across the lower front) o fmachine. form there you will gain acess to the "button trap" its a clean out for the pump assembly, sounds as if there is a something clogging the drain there fore preventing washer form high speed spin. beaware when the plug is removed there will be a bunch of water behind so be prepared with some towells, ( i use a kitchen plastic bag to collect water and any other gunk that may come through
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
  • 100 Answers
SOURCE: keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Posted on Dec 01, 2009
SOURCE: Goes into Pause mode during Delicate cycle. Model
Did you ever get this fixed? mine is doing the same thing
Posted on Jan 02, 2011
pctech1
  • 1940 Answers
SOURCE: It keeps on pausing during the cycles, what do I
It sounds like your Door Switch assembly may be faulty. During the cycles, the machine thinks the door is open, so it pauses the cycle.
Can you hear the machine drain? If not, this could be a Drain Pump problem, or Drain filter problem. You will need to remove the panel to access the Drain pump at the bottom of the machine. Remove the Drain pump hoses and clear them out. Make sure your Drain pump is also clear and turns freely.
Does the machine's drum spin? If not, you may have a Motor or Motor control board problem.
Posted on Feb 28, 2011
My Simpson eziload 750 will not shut off the water during cycles when supposed to
Start machine as normal. After a few seconds of filling, press the pause button. Water coming in should stop immediately. If it hesitates then stops or does not stop at all you have a faulty inlet valve. Change it.
Apr 22, 2016 | Simpson Washing Machines
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
MY FRIDGIDAIRE AFFINITY KEEPS PAUSING DURING CYLES DOSENT MATTER WHAT CYCLE I CHOOSE. IT STOPS ATLEAST 5 TIMES PER CYCLE AND SOMETIME WONT FINISH THE CYCLE. MODEL NUMBER FAFW3801LW3
Hi Brooke, thank you for allowing me to assist you!
Often this happens because the washer door is not securely latch or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, try reprogramming the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, then more than likely the unit has a faulty door latch, a communication error with the control board, or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Best regards!
Oct 30, 2013 | Frigidaire Affinity ATF7000E Front Load...
My washer keeps pausing during the cycle
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
It keeps on pausing during the cycles, what do I do to stop that?
Feb 28, 2011 | GE WSXH208A Front Load Washer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
