No power Kenmore Elite HE 4t Model The machine will not turn on. I have checked circuit breaker - reset and still no power plugged it in a new outlet - still no power (confirmed it worked prior) held down Drain/Spin button thinking control panel was locked
  • 1 more comment
  • KJ Jaeger Jan 21, 2013
    Kenmore Elite HE 4t is model
  • Richard Roth
    Richard Roth Jan 21, 2013
    Look inside to door area for the model number. It should start out like 110.xxxxxxx
  • KJ Jaeger Jan 24, 2013
    Richard - I ended up using my home warranty program from Columbia Gas Retail Services. $15 service call to find out the control panel had snapped off the "lid" of the washer and was resting on the drum slightly disconnected. New one ordered and on it's way. Thanks for your time!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Jan 21, 2013
  • 537 Answers
SOURCE: Kenmore 60 series washer
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Dec 07, 2007
  • 1028 Answers
SOURCE: KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Posted on Jul 31, 2008
donnastr
  • 10 Answers
SOURCE: Whirlpool washing machine power button won't turn the machine on
defective timmer
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
My kenmore elite oasis washing machine stopped mid wash there is no power at all. Model #110.28092700
first plug a lamp or something you know works into the outlet.if lamp does'nt work,check the breaker at breaker panel.If that is not tripped,it may be the onoff switch,or timer on machine.
Sep 27, 2014 | Kenmore Oasis HT High-Efficiency 4.6 cu....
When I plug in my kenmore elite oasis h e washer machine, all it does is show the letters pp in the time remaining window
The only way to reset a washer, is to disconnect it from the outlet or switch off the designated home circuit breaker for 20-30 minutes, then restore the power.
Oct 20, 2012 | Washing Machines
My Kenmore Elite Oasis HE washing machine is having problems. We can't find the owners manual but remember that there was something in it regarding reseting the machine. It is starting the cycle like...
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
The control lock lite is on my kenmore elite washer. How do I reset it, so that I can use the washer?
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front loader has no power.
the power is on but the start button does not start the machine
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite calypso and we had a storm last nite.And now it will not turn on??Is there a reset button on this washer.Thank you Ricky
Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Flashing PF
Dec 31, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE Elite HE 3T
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
