Question about Keurig Platinum B70 Coffee Maker
How do I remove the bad Plastic Smell & Taste from my Keurig B70 Platinum coffee brewer?
Water and coffee has a bad Plastic Smell & Taste.
  • 1,511 Answers
That should not happen. Return for a replacement. The heating resovour may have factory material in side the unit.
Posted on Jan 31, 2014
heatman101
  • 43501 Answers
SOURCE: the keurig platinum brewer spill water from the
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Posted on Oct 08, 2011
heatman101
  • 43501 Answers
SOURCE: I have a Keurig Platinum B70. When it brews,
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
  • 4 Answers
SOURCE: Removing the Top & Rear cover of my Keurig Platinum B70 Coffee Maker
well I had the same problem, it said NOT READY and would not draw water or heat it. I tried all the typical fixes for this problem. descaling with vinegar, taking out the waer basin and replacing it until it resealed itself, clearing the valves, turning on/off, unplugging, pressing menu rapidly after turing on, etc, etc, etc. I decide against taking it apart as I heard that it's a big pain in the bum. So I JUST BEAT THE LIVING **** OUT OF IT WITH MY FIST until volia it WORKED! ofcourse it died again a few days later. I've had it for two years and the warranty was up. costumer service was no help. So, the next day I went out and bought a new one of the same model, I switched this with the broken one and brought it back to the store saying it did not work. Let them return it to keurig and deal with those SOB's. hahaha hows that for a fix!
Posted on Dec 29, 2011
  • 67 Answers
SOURCE: I have a Keurig platinum brewer and the clear
i know of a site that sells all kinds of keurig parts for discount prices check it out i have used them before http://stores.ilikenew.com
Posted on Nov 17, 2010
SOURCE: Strong plastic smell and taste on a new Keurig Platnum coffee mak
I had the same problem and I discovered that after running 3 resevoirs full of water through the machine at 192 degrees , it got rid of the plastic smell. Set the cup size at the largest size mug and then just open the lid and close it , hit brew and let it fill the cup. Dump the water in the sink and repeat until you go through at least 3 resevoirs. The smell should be gone by then.
Posted on Dec 19, 2010
I donated a new Platinum B70 Brewer for use by our church staff. The tap water tastes terrible and ruins the coffee flavor!
and bench top or under bench water filter in the water supply line to the unit will work
best filters to consider are one ceramic ( removes particles to a measurement of less than 1/2 micron and one carbon filter that removes all taste problems
Aug 18, 2017 | Keurig Coffee Makers & Espresso Machines
The water won't pump through my platinum Keurig! I emailed the company & have not heard back from them.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Mar 22, 2011 | Keurig Platinum B70 Coffee Maker
MY KEURIG B70 IS CONTINUALLY PROMPTING TO "PRIME"
Hi, Lauren..
You can download another manual here.
Cleaning any coffee brewer is essentially the same. The easiest way is to brew one or more pots of white vinegar... it'll stink up your kitchen, but it's effective at removing build-ups and mineral deposits. Be sure to follow up these "vinegar brews" with several "plain water brews" to remove all the vinegar!
Also, if your water reservoir isn't clean (open the lid & do a finger swipe), you can use a brush to clean it or - what I do - wad up a paper towel or two, attach it to the end of a long-handled wooden spoon, and use that to get down deep into the reservoir & scrub it as much as you can before the vinegar treatment.
Alternatively, you can spend $3 or $4 for packaged cleaning compounds at stores like Williams & Sonoma.
Mar 02, 2011 | Keurig Platinum B70 Coffee Maker
Coffee maker never makes proper size, almost always have to run it 2-3 times to get even a small mug. Intermittently shuts off completely, have to turn it on in back. (B70)
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Jan 02, 2011 | Keurig Platinum B70 Coffee Maker
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
I have the platinum Series Quiet Brewer (cinnamon color) that I bought 3-11-10 on QVC. About 1 months ago it started shuting off after filling one cup of coffee, it fills the same amount of coffee no...
sdfdf
sfsd
fsdf
ds
Dec 23, 2010 | Keurig Platinum B70 Coffee Maker
Thin stream of water, only does a partial cup
weqwqwqw5555
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
283 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
