Question about Kenmore 97912 Top Load Stacked Washer / Dryer
Timer needs to be replaced...
How do I remove the washer knob to replace timer?
  • 3 more comments
  • Josie Jan 21, 2013
    It's a Kenmore stacked washer/dryer 97812. Sears ordered the timer part and I replaced it and plugged the unit back in but the washer still won't start.
  • Richard Roth
    Richard Roth Jan 21, 2013
    Look under the lid or inside the dryer door area for the model number. It should start with something like 110.xxxxxxx and post that number to me.
    Model 417.97812704
  • Richard Roth
    Thank you! That's the number I needed. The problem is not with the timer, it is with the lid switch. When the lid switch malfunctions, nothing will work. The tech you had out should have checked that. Here is the part you need to order.http://bit.ly/WbgLHe Also, here is the service manual for that model.https://docs.google.com/file/d/0BwHzXWK0...
  • Richard Roth
    The manuals I have cost me quite a bit of money over the years so if you can make a donation to help cover the manual cost I would greatly appreciate it as it will help to keep the manuals up to date and help other users. If you can't afford it, don't worry about it. I know times are tough. If you can, here is a link to my PayPal donation fund.https://www.paypal.com/cgi-bin/webscr?cm... Thanks in advance and keep me posted!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Jan 21, 2013
  • 2 more comments
    It's a Kenmore stacked washer/dryer 97812. Sears ordered the timer part and I replaced it and plugged the unit back in but the washer still won't start... The wiring looks fine, and the Sears technician diagnosed it as a faulty timer, I just can't wait two weeks for them to come out and install the part.
  • Richard Roth
    So, you already installed the timer and it still doesn't work? I'm confused now.
    Yes, I figured out how to remove knob and install the new one, but the washer still won't run. Nothing happens when I turn the dial.
    Model 417.97812704
5 Suggested Answers
  • 117 Answers
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: I need to replace the timer on a series 800 washer
Fix the timer on the washer so that it fills with the correct amount of water, and so there is the correct amount of time for each cycle. Make sure the washer is unplugged and take off the control knobs and the panel that lays over the knobs. The knobs could be either at the front or back of the machine. Check the wires that link the timer to other areas of the washer. If they are slack, push them further into place with pliers.
Change the timer by disconnecting the old one. Make sure the new timer is made for the brand of washer that you own. Unhook the wires to the old timer one at a time and connect each wire to the new timer.
Posted on Mar 03, 2009
  • 1937 Answers
SOURCE: removeing timer switch knob
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
See the following for how to release the console:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=d09053515715195798276a5664b79cf0
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If this is a basic top load, direct drive washer, these units may have one of two different timers. (See the Whirlpool PDF).
On models with a metal timer, you have to release the console, pull it forward and tilt it back in order to get to the back of the timer.
The knob screws onto a medal shaft that goes through the timer.
Usually, trying to un-screw the knob won't work by itself since the shaft will also turn.
I found that if you hold the back of the shaft with a thin needle-nosed pliers, you can unscrew the knob.
Then you simply have to disconnect the timer.
The Whirlpool PDF also has troubleshooting and testing procedures for the timer.
Posted on Jun 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: my kenmore 70 series washer timer stops on the
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
Removing timer knob on maytag washer mav2755aww
It unscrews or if it is a newer model, remove the console so you can tip it forward. You will see a (usually black or white) pin in the center of the timer, pull it out about and inch and then remove the knob from the front by pulling it off the timer shaft. Check you new timer and make sure it comes with one. So did some did not. Good luck.
Mar 28, 2016 | Maytag Washing Machines
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Need directions on replacing the knob-Timer Assembly for the WSXH208V1WW. Bought the replacement part but can't find any instructions for removing and replacing it.
Remove top of washer then Remove timer knob then (2) screws behind knob, un- plug timer connector and replace of course always unplug machine First
Sep 27, 2010 | GE WSXH208A Front Load Washer
I have a new timer to replace a broken one and I can't get the of
THE TIMER KNOB CAP REMOVES AND THIRS A CLIP UNDER IT REMOVE CLIP KNOB WILL PULL OFF YOUR SEE A SCREW OR 2 REMOVE TIMER MAKE SURE THE WASHER IS UNPLUG FIRST REMOVE BACK PANEL
Apr 03, 2010 | Maytag LAT3600A Top Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Series 80 Washer timer knob spins
Something in the timer came apart. Timer needs replaced. When in good working order, the timer should ONLY ever be turned clockwise..Reversing this could break it.
Mar 11, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Can not get the upper right dial off. It needs to be replaced.
remove console by taking 2 screws from the rear of it out, timer knob can be removed by squeezing pin at the center of the timer and pulling knob forward. Probably the timer needs replacing
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Kenmore 97912 Top Load Stacked Washer / Dryer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
