Question about HP Photosmart C5180 All-In-One InkJet Printer
Hp 6500A Plus improper shutdown - HP Photosmart C5180 All-In-One InkJet Printer
  • 169 Answers
SOURCE: HP C6180 - IMPROPER SHUTDOWN
Not a big problem,try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
ThiruBulls
  • 103 Answers
SOURCE: My HP C6180 is caught in a start up loop...
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Posted on Aug 21, 2009
SOURCE: HP PHotosmart c6150 keeps shutting on and off
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Posted on Feb 11, 2010
  • 100 Answers
SOURCE: hp photosmart c6180 all-in-one keeps
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the printer was having. A similar fix may apply to other printers. 859f1d1.jpg
Posted on Sep 26, 2010
mariolands
  • 2296 Answers
SOURCE: How to unjam a paper
Depending where the jam is you need to follow the appropriate solution. There's also a video on HP support website on how to clear a paper jam out of your HP Officejet 6500A Plus printer: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02441153&tmp_task=solveCategory&lc=en&dlc=en&cc=au&lang=en&product=4083977
Posted on Feb 13, 2011
Hp 6500A plus won't copy
Does it still print ok? To troubleshoot you should try to copy from the glass and through the automatic document feeder to make sure it is a problem with the scanner and not a piece of paper blocking the scanning path.
Feb 14, 2015 | HP "HEWCN557A - Officejet 6500A Plus...
Hp officejet 6500a touch screen not responding
Is the screen damaged or has water stains? If so power off the machine, use a dry microfiber cloth and gently wipe the screen. If the screen is still unresponsive, do a factory default reset - you will find this procedure in the manual.
Oct 16, 2014 | HP Officejet 6500A Plus Wireless...
6500a plus non hp cartridge over ride does not work
For print cartridge errors you may try following the article: Print Cartridge Errors. However, since they are refilled ink cartridges HP cannot guarantee that they will work correctly.
Can I Refill The Ink In My HP Ink Cartridge?
Don't forgot to say thanks by giving "Kudos" to those that help solve your problems.
Read More Help... HP Printer Support
Jul 24, 2014 | HEWLETT-PACKARD 6500A Plus InkJet Printer
Hp 6500a wont scan in win7 32bit
Make sure you have installed the scanner drivers for win7. I have the same printer and I can print & scan from Win XP, Win 7 & my iPad (All on wireless). Drivers for the printer & scanner must be installed.
Jan 27, 2014 | HEWLETT-PACKARD 6500A Plus InkJet Printer
Re HPOfficeJet6500A Plus printer. All lights are flashing on the front panel and a message reads C2FEO16C
Sounds like some firmware error.
Try disconnecting all cables for one or two hours. Then start again.
Otherwise call HP support.
Sep 09, 2013 | HP Officejet 6500A Plus
How to open and replace the ink cartridge from my 6500a plus
Simple, turn on your HP OJ 6500A printer and open top cover...carriage should move to cartridge access position. If not, then the service station may be in the way or the PRINTHEAD assembly is not properly locked down causing an error condition. Power supply could also cause this kind of failure.
For information on North American ink refill services (i.e. HP920 and HP920XL ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP Officejet 6500, 6500A, 6500A Plus, 7000 and 7500A printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 13, 2013 | HP Officejet 6500a Plus E710n Printer...
Hp 6500a plus printhead won't print
As you said that you have already cleaned the print heads it could be the contacts inside the printer has gone bad. Its suggested by HP that if you get any error regarding the print head you should contact them and they will replace the printer. Please do so. Thanks.
Dec 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp printer officejet #6500A plus manual how to use printer
Manuals and drivers for the 6500A Plus are available here: http://h10025.www1.hp.com/ewfrf/wc/product?product=4083977&lc=en&cc=us&dlc=en&lang=en&cc=us . Support for the 6500A is here: http://h10025.www1.hp.com/ewfrf/wc/product?product=4083871&lc=en&cc=us&dlc=en&lang=en&cc=us .
Most of the printers work the same way. Install the software before you connect the printer to the computer. If you are going to use a wireless connection, you need to install the software then connect a USB cable and then continue the installation before disconnecting the USB cable and going to the wireless connection.
The scan buttons on the unit will only work if the full software is installed and set up (scan from the computer first) and the monitoring program is running.
For more specific information, please indicate the connection type and the OS that you are using.
Feb 17, 2011 | Office Equipment & Supplies
How to unjam a paper jam in an HP Officejet 6500A Plus
Feb 13, 2011 | HP Office Equipment & Supplies
HP Photosmart C5180 All-In-One InkJet Printer Logo
170 people viewed this question
Seeker5211
Seeker5211
