Question about Sharp LC46SB54U 46 in. LCD TV
Power light flashes intermittently and will NOT power up.
Worked fine until the other morning when i turned it on it turned itself off after approx 3-5 seconds. This repeated twice then all I get now is the power light flashing intermittently on and off. I have disconnected the power cord for several hours guessing that it might reset its self but the problem continues. Approx two years old.
    Genius:
  • 1,003 Answers
Replace mainboard and powersupply!
Posted on Jan 21, 2013
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 8457 Answers
SOURCE: Aquos model LC46D64U...approx 2 years old..Won't
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Posted on Oct 18, 2010
bshldn
  • 736 Answers
SOURCE: TV will not turn on. There are two lights in front
Sounds like your screen is broken or has been impacted. Force the television on by doing this: Unplug it and on the side of the television where the panel buttons are hold down the ch- and vol+ buttons. Then plug in the television while still holding them down. The television should come on and you see the cracks. Unfortunately it can't be repaired.
If it isn't ch- and vol + then try ch + and vol -.
Posted on Feb 05, 2011
  • 99 Answers
SOURCE: I own a Sharp Aquos
there is a problem with the power supply. most likely too much ripple that is ac leaking into the dc. I have seen the power supply repaired but it is not always possible. If there is an obvious swelled capacitor on the power supply that can be replaced this will be the best bet for repair. If there is nothing visually obvious then it gets a little harder since you won't really know which component is not working, the tv shuts down on a protection circuit so if the power supply can be repaired and the voltage "cleaned up" then the tv could work again. I have also seen replacement power supplys sold.
Posted on May 26, 2011
Testimonial: "Thank you for your insight. Much appreciated."
diodeic
  • 1622 Answers
SOURCE: Sharp LC -46SB54U will not
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Do take care.....
Posted on Jun 16, 2011
Will not turn on
Probably a spontaneous power supply failure.
Jan 07, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Set is an LG DLP model RU 52SZ51D. Set sometimes needs to power cycle 20 or more times to fire up. Other times 1 or 2. The red led turns to amber and flashes approx 55 times and then turns to red and...
I need to know titles of lights that blinks on tv while it trying to power up. There are Power, Lamp and Temp lights, let me know what light blinks, this will help me to diagnose the problem as I hate to guess like try this and try that.
Thanks.
Aug 26, 2010 | Televison & Video
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
ZyXel Prestige 660HW T1, power light blinking
It's dead, sorry. You could TRY removing the power cord, holding in the reset button and powering it back up with the button HELD DOWN for at least 10 seconds. That will factory default it, so I hope you know how to program it all again! (please don't contact me and complain if you don't...)
May 26, 2009 | Zyxel P660HW-D1 Router
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Motorola L6 erratic ability to turn on
you need to take the phone to a mobile service center and have them reflash the firmware on the phone and that will correct the problem
Dec 26, 2007 | Motorola Mobility L6 Cellular Phone
TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
May 02, 2007 | Toshiba 27AF41 27" TV
Sharp LC46SB54U 46 in. LCD TV Logo
142 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
