Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
Yard machines 13A1762F what is the year - Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
3 Suggested Answers
  • 2468 Answers
SOURCE: I have a Yard Machines
did it possibly shear the flywheel key?which would throw it out of time,remove the top cover and see if the key is sheared off by removing the flywheel
Posted on May 29, 2011
hfberwald
Recently had same problem with this machine with a Tecumseh 17.5hp. There is a solenoid on the bottom of the fuel bowl that controls fuel flow inside the carb. It is controlled by the ignition switch. Mine got stuck in the closed position. I could not find a replacement, so a small engine mechanic told me I could disable this by removing the solenoid and cutting off the pin. This worked for me. Then, for safety, put a fuel cutoff valve in the fuel line.
Hope this helps.
Hank in Marietta, GA
Posted on Sep 19, 2015
Yard machine riding lawn mower 13a1762f will start, engage blades, once i begin cutting grass mower will run for a minute then shuts off
Try checking the gas tank cap vent hole to see if its clogged. These have a tendency to get clogged with dirt, and when it does the tank start to pull a slight negative vacuum, stopping the flow of gas into the engine. Usually you can just blow it clean.
Aug 12, 2016 | Garden
Engine sputtering idle
have you tried a half of can of seafoam?
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 15, 2013 | Yard Machines Garden
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Have a 22 inch yard machine snow blower the belt that turns the blades broke what size belt does it take
MTD has made many 22" machines over the years. Please repost your question indicating the model #
Dec 27, 2010 | Mtd 22" Yard Machine Push Mower
I charged the battery on my yard machines 12.5 riding mower but when I tried to start it I get nothing. The lights don't even come on in the accesory position
sounds like a dead battery.
if it's more then 1-2 years old time to get a new one.
also check the fuse in the line close to the start relay.
Dec 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Thee is no serial or model no. plate on my mtd yard machine tiller. I need a diagram of the gear mechanism, when I split it apart all the gears a nd chain fell out.
Had the same problem with my MTD Yard Machines 5 horse tiller. I called MTD at 800-800-7310 and with the model and serial and such off the engine - which are stamped into it - a nice lady was able to narrow down my tiller year. From there with horsepower details she narrowed further to one of two models that I could look up on the MTD corporate home page and get a schematic.
Hope that helps.
Jun 17, 2010 | Mtd Products Yard Machines 158CC Tiller
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
147 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
