Question about ASUS U Computers & Internet
Fixing start up shutdown asus aspire - U ASUS Computers & Internet
  • ASUS Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty. even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly. Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be running your computer over its limits causing memory dumps also under processes see what is ticking over in the background you might have a virus again if you see something you dont need to be and users you will see who is using your computer
You might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility of the ram before making any purchase Might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/
Hope this helps.
Posted on Jan 21, 2013
    Problem Solver:
  • 14 Answers
Can you please give us a clear idea. whats your actual problem is ?
I have Asus laptop series K501e, the laptop would not boot or power up after normal shutdown. After searching the net for fixes I purchased anew battery and power supply with new leads. This did not work,...
Ebay battery? made in china? that happen a lot.. most laptop battery are designed with the proper voltages, Watts so on and so forth.. don't be fooled on a cheap battery sold on ebay it may works but only few times, what it does is restricting the power to your laptop and obtain time laptop can't handle the power... buy OEM replacement battery..
Aug 21, 2013 | ASUS Computers & Internet
My ASUS (VW190) LCD monitor shutdown for 1 to 2 seconds after turning on with full image then the LED indicator is still in blue color. Once I press the power button off and on, the screen displays again...
I have the same problem on my ASUS vw190. everybody is talking about capacitors poped. 2 solutions are posted, firstly replacing the capacitors is best, secondly reducing the brightness to 50% solved the problem for me. screen still fluctuates. going to have a look inside. i will be back with more feedback.
Nov 04, 2012 | ASUS Computers & Internet
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
Jul 04, 2012 | Acer Aspire 5742 Notebook
My acer aspire 4736z auto shutdown within a few seconds after on. Is there anyway to fix it?
yes there's a fix a simple one
1.it may be due to a loose ram..
2.your laptop may be over heating with leads to auto shutdown
solution : a service will solve all your problems !!
Jun 14, 2011 | Acer Computers & Internet
It shuts down about a minute after you start it the acer aspire one
canning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire 4520 starts the comes off a few seconds after pressing the power botton
hi, yes the laptop will shutdown if you press power button.
it send command to OS that it required to shutdown in emergency so it shutdown in force. so do not shutdown by pressing the power button. use start> shutdown option.
i hope this will resolve the issue.
Jun 23, 2010 | Acer Aspire 4520 Notebook PC
My files on the start up are all opening with the same icon and i cannot change it back. How do i set the default settings so all files are individual
as i said before try the shutdown option, let it shutdown then press power button gently and see what happens.
if that doesn't work type in trouble shooting in the seach box on the start menu. look for find and fix problems. just let the it run. it should find the problem and possibly fix it. hope this helps
Apr 02, 2010 | Acer Aspire 5610-4648 Notebook
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
