Question about ASUS U Computers & Internet
HOW TO FIX SHUTDOWN START UP ASUS ASPIRE
SHUTDOWN BY ITSELF WHEN START
  • ASUS Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 21, 2013
My Eeetop turns itself off frequently
Check for viruses or corrupted files or recently installed software that may not be compatable with your operating system. Any of this could cause it to shutdown randomly also check for your Fan Vents that are dusty and not flowing well or at all....this could make it overheat and shutdown as a safety precaution. Worse case is the motherboard might be going bad but don't assume this is the problem..... Last resort do a system restore (under the start menu)
Nov 03, 2013 | ASUS Eee Top ET1602 PC Desktop
I have Asus laptop series K501e, the laptop would not boot or power up after normal shutdown. After searching the net for fixes I purchased anew battery and power supply with new leads. This did not work,...
Ebay battery? made in china? that happen a lot.. most laptop battery are designed with the proper voltages, Watts so on and so forth.. don't be fooled on a cheap battery sold on ebay it may works but only few times, what it does is restricting the power to your laptop and obtain time laptop can't handle the power... buy OEM replacement battery..
Aug 21, 2013 | ASUS Computers & Internet
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
Jul 04, 2012 | Acer Aspire 5742 Notebook
Hello!,My name is james I have some problem with my laptops asus x8ac is powering of and I don't know,what's to do.Don't you have some guide for to do it,please!
Hi, Turn off the laptop and press F8 and start on a safe mode. Then click start click accessories, click system tools click system restore. You may choose system restore point and click system restore and wait. The system may shutdown by itself but don't worry just wait and let the system do the task. It will reboot and look on the screen if the system restore successfully. Get back to us if this information help you solve the problem.
Jul 07, 2011 | ASUS Computers & Internet
My acer aspire 4736z auto shutdown within a few seconds after on. Is there anyway to fix it?
yes there's a fix a simple one
1.it may be due to a loose ram..
2.your laptop may be over heating with leads to auto shutdown
solution : a service will solve all your problems !!
Jun 14, 2011 | Acer Computers & Internet
How do i reboot my acer aspire e500
If in windows, look under the "start" menu for "shutdown". If that doesn't work, most PC's will shutdown if you press and hold the power button for roughly 5 seconds, but doing this can be negative for the equipment if the operating system doesn't respond in time. You might try just pressing the power button one time to see if the O.S. will respond and attempt to shut itself down gracefully. If it doesn't, then just hold the power button in till the machine cuts off. Hopefully, you won't have to make a habit of that. The ideal way to shutdown is to "tell" the O.S. to shutdown, so it doesn't cause a hard drive head crash or file corruption, which while both are remote, are still a potential with a hard loss of power.
Dec 29, 2010 | Acer Aspire E500 PC Desktop
It shuts down about a minute after you start it the acer aspire one
canning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My files on the start up are all opening with the same icon and i cannot change it back. How do i set the default settings so all files are individual
as i said before try the shutdown option, let it shutdown then press power button gently and see what happens.
if that doesn't work type in trouble shooting in the seach box on the start menu. look for find and fix problems. just let the it run. it should find the problem and possibly fix it. hope this helps
Apr 02, 2010 | Acer Aspire 5610-4648 Notebook
Acer t310 fan runs when shutdown
More than likely the cpu is still hot even after you shut off you computer, so as a saftey precaution the fan is trying to cool it down,(which is a good thing).
Jan 06, 2009 | Acer Aspire™ T180 PC Desktop
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Computers & Internet Logo
90 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
