Back to:
Tags:
Dacor ECS130 Epicure Electric Single Oven
Dacor Oven Won;t Heat (by 2 users)
posted by cernikj on Jul 19, 2007
I have a Dacor ECPS130 single oven. Last night we had a power outage and when the power came back on I got the F1 error code and it was beeping. After hitting cancel/secure a few times the beeping stopped. Now when I try to use the oven it goes into pre-bake but does not heat and then it turns off. I tried resetting the limit switch but that does not seem to do anything. Any ideas?
Comment by cernikj, posted on Jul 20, 2007
Thanks Dog,
As it turned out we waited a couple of hours and tried the oven again and it worked just fine. I don't know if something needed to reset or what but it seems to be fine now.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Seastars, posted on Dec 16, 2007
I have the same problem: my newish Dacor oven will only do pre-bake (135 degrees) when I press either Convection Bake or regular Bake. The oven worked for over a year with no problems, and just rbegan this. There are no error messages; the orange letters under the current temp say "pre-bake on." We have NOT had any power outages.
Best Solution
FixYa! (100)
The dog
Rank:Guru Guru
Rating: 86%, 214 votes
power surges can short out the electonics in appliances. If you can locate where the tech sheet is and I would say its behind the control panel on top, look at the wiring diagram and see if there are any replaceable fuse's. Or a resetable fuse for the heating element. If not check to see if power is getting to the main control bord. If there is power there you may need to replace the control.
Rating Locked! (?) cernikj has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dacor Oven Won;t Heat:
I don't want to Accept this solution
Can you Help with these Ovens problems?
Ovens
One of the top elements of my stove occasionally raises...
Ovens
My mother has a sunbeam fireplace. The lights come on but...
Ovens
The locking lever will not move to the clean function when...
the oven is turned off but it continues to beep. how do we...
My oven started beeping for no apparent reason. I poked...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
