Question about Sanyo R227 WiFi FM Radio
No power sanyo r227
Area power failure. On/off a few times. Now radio will not power up. Unplugging does not help. Only repeated short bursts of static. No power to display. Is there a fuse inside?
    New Friend:
I tested the power supply output voltages (on the small board with the transformer and capacitors on it) and found 0v at the 5v terminals, and 3v at the 12v terminals. I have asked my son, who owns a computer repair biz, to find a suitable new power supply.
Posted on Mar 22, 2014
    New Friend:
I had the same problem. A defective capacitor is trying to charge near the audio chip .
My solution : I have remove the audio chip (the one with big heat sink) and I use the aux out output to my amplifier.
When plugging it takes some time to finally work : but once plug and working it stays on and work ok.
Posted on Apr 26, 2013
  • Yves Brissette Mar 23, 2014
    The power supply is the real problem, If you feed it from an exterior one : its works fine ! I also changed all electrolytic capacitors of the power supply : it now works.,
Cal I bye a new or referb power supply board?
If you can get a refurbished power supply board, buy it. They are as good as those new from factory. I bought a refurbished Sony Radio - Cassette - CD player 23 years ago and it's still good!
Aug 08, 2015 | Sanyo R227 WiFi FM Radio
Replace remote
. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 17, 2014 | Sanyo R227 WiFi FM Radio
After return of a power outage, my R227 was rendered"dead", presumably because of voltage spike. Is there a fuse in the interior which might be open?
Yes there is. It is just inside the back cover on the right side looking from the back. It is located at the end of the brown wire from the power input jack. It has a plastic cover over it and is a
T2AL 250 volt (2 amp slow blow) with pig tails on it.
Dec 26, 2013 | Sanyo R227 WiFi FM Radio
Sanyo r227 no audio
you clean the head of radio or otherwise it have speaker problem.
Mar 16, 2013 | Sanyo Audio Players & Recorders
Have a Sanyo Plasma TV DP50747 and both picture and sound all of a suden went. I turned it on from the remote and the green power light goes on, but no picture or sound and the power light goes off again...
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Jan 10, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Having Trouble Receiving Through"TPL"
Are you sure that you are using the exact RX Frequency? is the radio in 25Khz if this radio is working on 12.5Khz with the IF filters changed to work in narrow band (12.5) could happend this.
Do you know if the repeater is on parameters mostly of the cases when an over modulation is received this will cut the PL modulation for short periods.
If the radio transmit over modulated could "erease" the PL modulation for short periods.
I think this radios should be checked all the Tune parameters to make sure is ajusted properly.
Good luck
Dec 17, 2007 | Motorola HT1000, MTS2000, MTX8000/9000...
Sanyo R227 WiFi FM Radio Logo
628 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
