I have a printer that i want to instal, i conected to my laptop and is asking me for a disc to get it instal. which i don't have, what can i do or what are the steps i have to follow.
    President:
  • 2,692 Answers
Go to the website of the manufactor of your printer.Go to the driver downoads.Look up the model number then select the correct windows version. Downoad the driver and other software as well. You may also want to download a manual from this same website if you have not one.   If you have trouble doing so, give me the the make and model of the printer and tell me the version of windows that you are using and I  will look up the link for you or let  you know if it is unavailable and why, if possible. Thanks .
Posted on Jan 27, 2009
I have a emachine e528 laptop when I cut my computer on it just shows a blinking white underline in the top left corner how do I fix this?
First things first. Make sure you don't have anything connected in the USB sockets or the bays (CDs etc). Disconnect from the charger and also remove the battery. Hold down the 'on' button for 10 seconds...this will reset your laptop. Reconnect to power and try to switch on again. If the laptop still doesn't function it may be a RAM problem or a hard disc problem (you can try removing and re-installing both). It's worth trying a Windows installation disc to see if the laptop can boot from that. If it can, that will prove your RAM and motherboard is OK and indicate a problem with loading Windows. You don't say whether you get any 'splash' screen....that's the one that usually gives the manufacturers name briefly. If you don't even get that, it could be a bad omen. If you can get the Windows installation disc to boot, you can do a repair installation. To do that you go right through the installation procedure until you get the prompt asking you if you want a new installation or repair installation. This is different from the Repair Console- don't select that. You may find that the installation fails because the hard disc is no good. In that case you will have to transfer your data onto a new disc, there's free software to do that (you will need another laptop or PC)
Sep 26, 2012 | Computers & Internet
I put in the install disc and at the start it says that it wont install 100% cause of Memory only 893MB (recom 1000MB), I don't understand cause the computer Memory 1024MB, what am I missing? Plea
Its don't Ask for your RAM (Read Only Memory), but it's require Hard Disk memory... so please check free space in your Hard disk... if its less than 1000mb then free some space........
Sep 01, 2012 | Lexmark X2670 All-In-One Printer
I need the software to install it at my new laptop and i don't have the disc.
You can download the drivers online: http://bit.ly/N1Pt31. Just choose the Operating System of your computer.
Aug 30, 2012 | Lexmark C540N PROD SPECS TBD Printer
How to download printer to laptop
Install the printer driver into the laptop and connect printer to laptop via usb. There may be a specific way to do this, so you should consult your printer manual. If you don't have the printer driver disc, you can download one from the printer manufacturers website.
Mar 20, 2012 | Computers & Internet
I don't know how to connect a printer (HP 970 Deskjet Cse) to my lap-top HP Pavilion dv7
Go to the website below, select your OS, and download the drivers. Than install the drivers and follow the instruction. It will ask you to plug the printer via usb at some point.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=60097
May 03, 2011 | HP Pavilion dv7-1132nr Notebook PC
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
I just got a printer but i don´t know how to install can you help me
First get the printer ready to hook up but do not hook it up. Second boot up your computer and insert the disc that came with the printer, once the disc is in it will pop up a window, something in the window will say something about setup or install, click on that and follow the step by step installation instructions, at a halfway point through this couple of minute installation, the installation will ask you to hook up the printer, which you should do, and finish the installation, then reboot the computer and you should be ok to take out the disc and finish.
Oct 30, 2009 | Office Equipment & Supplies
Can't conect with my computer
You prob had the printer plugged in and then installed the software,
To Fix:
1. Plug in and turn the printer on
2. Attach to Laptop
3. Hit esc if Windows asks to install new device (3-4x)
4. Uninstall the Printer Software from your Laptop
5. Disconnect Printer from Laptop
6. Reboot laptop
7. ReInstall Printer software from CDROM. ONLY
when it is DONE installing software and TELLS you to, THEN connect the printer. Now it should work ;-)
Mar 26, 2009 | Canon imageCLASS D860 All-In-One Laser...
Hello here! i have tried to install my lexmark x5150 to my compacq laptop, and cant get it to print, i have installed the disc countless times wiyh out any progress can you help?
Try this:
first uninstall the disc's software
than restart the laptop
if correct it will automaticly detect your printer and ask for the disk.
cancel the installation.
Insert the disk and cancel the automatic running program for installation.
go to start, printers, add new printer and follow the steps from there untill it says "have disk" click on have disc and brose to your CD drive. It will automatically indicate which program it requires, search on the disc that program and click OK and continue the steps.
Reason: automatic installations from manufacturers sometimes do not install all files needed by windows, installing via windows itself it will automaticcaly pick the correct files from the disc.
Jan 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
29 people viewed this question
jasbo
jasbo
