Question about Stanley Camping, Backpacking & Hiking
Stanley tripod flashlight maxlife 369
Lost an end cap on one leg to hold the batteries in can you get a new end cap
  • 8404 Answers
SOURCE: flashlight only works when end cap is partially
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Posted on Dec 05, 2009
RALilja
  • 381 Answers
SOURCE: where do the batteries go
Hello, The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck! Rich L.
Posted on Nov 28, 2010
SOURCE: how do i install batteries on stanley 95-112
I just found it! The batteries go into the tripod legs! genius
Posted on Jan 05, 2011
  • 172 Answers
SOURCE: How do you install the
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Posted on Jun 27, 2011
SOURCE: I have a Stanley tripod
After drilling each leg to remove my corroded batteries I found that each leg isa push fit allowing it to seperate from the body thus allowing a screwdriver to be pushed thru releasing the corroded batteries. Re-assemble assuring a tight fit to make connection and it works well. Good luck I was drilling 1 leg for hours and the other 2 took ten minutes.
Posted on Oct 14, 2011
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
How do you chance battery on a stranley tripd flashlight
unscrew the caps at the bottom of each leg - each leg holds 3 AA batteries (9 total)
Jan 05, 2013 | Stanley 3in1 Tripod LED Flashlight 95155
Where are the batteries located in a Stanley Tripod flashlight
You'll need to remove the base of each leg by unscrewing the black cap at the bottom. Insert the batteries into the tripod leg. Each leg holds one to three AA batteries depending on the flashlight size.
Aug 24, 2012 | GE Photography
I have a Stanley tripod flash light that taked 3 AA batteries in each leg of the tri pod. On one of the legs the batteries corroded inside and I can't seem to get them out . Any suggestions to this...
Aug 09, 2011 | Stanley Bostitch Maxlife Mini Tripod...
How do you install the batteys in the stanley tripod legs?
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
How do i install batteries on stanley 95-112 tripod flashlight
Dec 30, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have maxlife 369 tripod. how do i put in new batteries
unscrew the caps on the bottom of the legs - each leg has 3 AA batteries
Dec 29, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Where do the batteries go in my stanley tripod flashlight?
Good Luck! Rich L.
Nov 28, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have been given a stanley 95 111 flashlight. dont know how to replace batteries did not get a manual with it
You can remove either the cap or the end and replace the batteries that way. They twist counter clockwise.
Jul 19, 2010 | Stanley The Work Bostitch Security Pocket...
Camping, Backpacking & Hiking Logo
52 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
