Question about Maytag MSD2756G Side by Side Refrigerator
Maytag msd 2754 gr control panel clicking and making light come on and off while light switch is off
The control panel is clicking in a fairly consistant pattern and when it does 'tick' the external light clicks on anf off event though the light switch is in the off position. Unit is cooling fine wayer lines not hooked up
watugot
  • 290 Answers
SOURCE: maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Posted on Oct 10, 2007
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
nallbunch1
  • 8 Answers
SOURCE: dispenser not responding
On mzd2766 there is a solonoid type switch that goes bad. Could be your problem too.
Posted on Apr 30, 2009
  • 235 Answers
SOURCE: MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Posted on Jul 01, 2009
  • 24 Answers
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
Does my green wire hook to my msd 6al box
You need to contact MSD support on this, if I advise incorrectly you might destroy the new MSD ignition control
Jul 18, 2016 | Cars & Trucks
Where is the defrost timer in MSD 2732 GR
Timer defrost motors are usually behind the bottom front grille.
Sep 29, 2014 | Refrigerators
Casablanca Intellitouch Fan was working fine.. Then only the light worked and fan switch made a quick bleep and started the blades moving but then both light went off and fan stopped. Now nothing works and...
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
May 15, 2010 | Casablanca Fan 3245T Ceiling
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
Maytag refrigerator ice dispensing panel light indicator stay on all the time. It supposes to come on only when the button on the back is pressed against by a cup. Need to find the root of this bug. Model...
forgive the question but are you sure theres not a "nightlight" option or a light on/off switch( perhaps even right under he dispenser by the light bulb itself???? i only ask because the diagram i pull up isnt clear at all, and that is an option on most dispensers
Mar 15, 2008 | Refrigerators
Dispenser not responding
Aug 16, 2007 | Maytag MSD2754G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
