Question about Bosch ProTankless GWH 715 ES LP Tankless Water Heater, Propane
Burner will not light
Tankless water heater pilot lights but burner will not light
The model I have will not come up - The model we are having a problem with is Bosch ProTankless GWH 425HN - Please advise.
Thank you
  • Anonymous Mar 31, 2014
    Burner fail
  • 33 Answers
Try this web site!
http://www.protankless.com/BoschProHome/GasProducts/BoschGWH425HN/tabid/506/Default.aspx
Copy & Paste to Google search engine.
Posted on Jan 27, 2009
I have a bosch aquasar 125b tankless water heater and the burners do not light when hot water is turned on this also causes the pilot light to go out
possible faulty pressure switch connected to the water line and that is failing to turn on the main gas tap solenoid
best have it checked by an accredited gas fitter or service center for the make
Aug 20, 2016 | Bosch AquaStar Indoor Natural Gas Tankless...
The pilot light went out on my aqua star 125 BNG tankless water heater. I lit the pilot and the burner started and now the burner won't go out it when I turn the water off Serious business anybody got...
Before calling service technician, copy following links for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jul 13, 2012 | Water Heaters
Our tankless water heat will not heat the water-it won't ignite
Question posted under Boasch tankless. Model number not known.
Before calling service technician, open following link for Bosch troubleshooting resources, including phone and contact for Bosch, error codes, and possible manual, plus hours of reading and research:
As you know from reading manual, tankless water heaters require yearly maintenance by trained service technician, or by homeowner. This action would check gas and pressure, venting draft, condensation drain, burner and combustion parts, igniter and-or pilot light, electrical connections, air intake and general condition of plumbing.
Problem you describe does not include error code.
Open following link for possible help with general plumbing problem:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with model number that appears on side of unit, and I can directly locate possible service bulletins and further troubleshoot resources available at Bosch for possible do-it-yourself diagnosis and repair.
Sep 02, 2011 | Bosch & Tankless LP Hot Water Heater
Once in a while after burner has been on and shower has been on for a while, the burner shuts down and pilot flutters, then pilot comes back on good but no burner .eventualy burner comes back on. if i turn...
Probably the burner and parts need to be cleaned yearly as recommended in most gas water heater manuals. Both tank and tankless today recommend same.
Open following link for Bosch troubleshoot resources:
Jun 20, 2011 | Bosch AquaStar Natural Gas Tankless Water...
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch GWH 425 HN Tankless Hot Water Heater...On 2/28/2010, it began intermittant exploding when demand for hot water occurred. Local technicians worked on the unit several times, changed and...
I have the same problem with the same model. The problem has been identified by a friend of mine, correctly, I think.
This is a very dangerous problem involving Bosch's much touted safety feature, ironically enough. IT IS THE FLAME SENSOR IN THE GAS VALVE. The flame sensor is supposed to confirm that the pilot has lighted BEFORE the main gas line sends gas to the main burners, after which the pilot shuts off. The pilot light is not coming on, the sensor that shouldn't let gas fto the main burners is failing and the main gas is flowing and ignighting from the spark that is supposed to light only the pilot in a big explosion.
This is the 2nd unit of this model that has failed. I think Bosch should do a recall
Apr 25, 2010 | Bosch & Tankless LP Hot Water Heater
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch ProTankless GWH 715 ES LP Tankless Water Heater, Propane Logo
542 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
