OPERATING MANUAL FOR TEMPUS FUSIL MANTLE CLOCK
5 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: Antique Forestville Mantle Clock
Middle Key hole for the time.
Left side is for Chime
Right side is for the strike.
r/
David
Posted on Jan 22, 2010
  • 299 Answers
SOURCE: I need a Howard Miller battery mantle clock
Try www.klockit.com. You can replace the entire movement for about $5 including new hands. You can select from an assortment of hands that will probably match the style of what you have and use those if the old hands don't fit the new movement. I've bought several movements from them over the years. For a few more dollars you can upgrade to an "atomic clock" movement which synchronizes with the US time signal and even sets DST automatically.
Posted on Apr 15, 2010
  • 1218 Answers
SOURCE: how do i obtain a
What does this have to do with FAX machines.???
Posted on Oct 18, 2010
cashley199
SOURCE: tempus fugit westminster mantle battery operated
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Posted on Aug 18, 2012
Seth thomas manual for models E658-E659and E662-E663 series floor clocks
Try Googling (seth Thomas)(*)(manual) without parens.
* E658, E659, E662, E663. Search models one by one.
Nov 15, 2017 | Seth Thomas Home
I have a daniel dakato tempus fugit clock and i do not know how to make it chime on the hour
Try Googling (daniel dakato)(model)(manual) without parens for instructions.
Jun 23, 2017 | Chime Home
Forrestville mantle clock
RECOMENDATION:
Seek professional help.
For this question it will be hard to evaluate it from here.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Watches
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
Feb 08, 2010 | Seiko Mantel Clock
Drayton tempus seven
I have jjust found a manual for this system. The unit has a plastic cover on, which is not that obvious first. After opening the cover there are some buttons ( i.e. Clock). First press clock and re-set correct time. Then just press the relevant button ( i.e 1st on to set the time for having the heating on first thing etc. For each day, afert pressing Day button, the same can be set.
I think the key is to realise that there is a front cover, which hides the buttons. Hope this helped.
Oct 12, 2009 | Dayton Water Heaters
r/
David
Aug 25, 2009 | Seiko Chiming Pendulum Tambour Mantel...
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
 Grubhead
Grubhead
