WASHING MACHINE STOPPED AND ALL LIGHTS ARE FLASHING
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Jan 21, 2013
  • 417 Answers
SOURCE: washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Posted on Jan 23, 2010
Testimonial: "that worked a treat thanks"
barkencoa
  • 3463 Answers
SOURCE: Machine wont stop washing on programme 9! went for
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Posted on Feb 10, 2010
Testimonial: "Thanks for that and you are correct!! It was the heater element. I put it on to a hot wash and couldn't hear it heating up so called in the experts!"
rylee_smith
  • 8619 Answers
SOURCE: washing machine stopped, it is beeping and
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: my vision hd washing machine stopped working half
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
  • 9 Answers
SOURCE: I have a beko 5140w
check the timer..
Posted on Oct 11, 2010
When I on the machine LG WF-F5700PCX ,all the lights are blinking. water is not flowing in.
Washing machine all the lights flashing, error codes on ...
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
Washing machine lights flashing - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
Flashing Lights on Washing Machine How to Repair ...
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
Indesit Washing Machine Repair: Flickering Or Flashing Lights
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
Jan 11, 2016 | Washing Machines
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Washing machine will not start, only get two red flashing lights, what could be the problem ?
Sounds like something toasted on the control panel
Better call certified appliance repairman
Oct 08, 2014 | Russell Hobbs RH1042 Frontload Washing...
Main wash and rinse lights both flashing together and machine stopped
main wash and rinse lights both flashing together and machine stopped
Feb 09, 2011 | Miele Novotronic Premier 500 Front Load...
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I have a Fisher & Paykel washing machine. Model MW512NZ. It has stopped working properly. The water is stopping and starting when the machine is filling and although the machine will pump out it will...
Hi just read your posting.Now the lights that are flashing will be in a row of 8 lights.Starting from the left to right which lights are lit,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with the additional information and I can help you rectify this fault.Looking forward to your reply.
Aug 01, 2010 | Fisher and Paykel Washing Machines
Hotpoint washer dryer BWD 129 stopped and won't drain or spin
unplug for 40 minutes in an attempt to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
