Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
ASks me to ventilate but it doesn't ventilate when I try and then it just keeps cycling over and over
I am getting a VENTILATE request that when i try to do it, doesn't ventilate, hums slightly..a bit of vibration, no steam or water and then afetr a few seconds asks to close know. Then the cycle repeats over and over. I have tried using a pin to unplug the steam wand at base of nozzel and to push air through with a bicycle pump but nothing helps. I belive that maybe there is an air buble somewhere and I dont know how to get to the tubs or tap rods or anywhere else per various articles.
3 Suggested Answers
  • 1618 Answers
SOURCE: Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Posted on Jul 29, 2009
  • 1089 Answers
SOURCE: I have a Saeco Royal
You only push the water button. Don't turn the knob, that is just for steam. There is a button for the cappuccinotori though, that you push.
Posted on Apr 15, 2010
Saeco Royal Machine says "ventilate", but when we
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
Screen indicates to ventilate and won't allow any fuctions till ventilated. Have ran ventilate cycle several times, however machine still indicates to ventilate. Water flow is extremely low to nil when...
If you open the steam knob and only can get a half cup of water, then your flow meter in the machine have to be replaced.
If you need to replace the flow meter then it has spare part number: 286473300
Make sure to descale your machine often.
Jul 20, 2008 | Gaggia Titanium Espresso Machine
Keep getting ventilate message - won't ventilate and cannot operate steam or grinder w/ ventilate message
Try this run the hot water cycle for a few seconds, it that works, try steaming if you get the message again clear it by running the hot water cycle and then go to steaming, this time push in on the knob after you open it, it that works, then the tap rod or the valve assembly needs to be replaced.
May 01, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Keep asking to ventilate,when ventilated,coffee does not come out
Run CLR through a couple of cycles and flush with clean filtered water through a couple cycles. Try to use filtered water to prevent lime and calcium buildup, besides, the coffe will taste better - Godd Luck-Ned-
Aug 23, 2009 | Saeco Royal Cappuccino Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Machine Is Stuck on "VENTILATE" Command
Sounds like you all have the same problem. Your flow meter has been obstructed with a small chip of coffee bean that got into your water tank receptacle when your tank was off. You need to remove the top or back depending on your machine and remove the flow meter. It twist apart. The intake is a small opening and that is creates the jet of water that spins the flow meter. If it gets obstructed the meter doesn't spin and you will get the ventilate message.
Dec 05, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
