Question about LG Flatron 915FT 19" CRT Monitor
Ballpoint ink on screen
How do I remove ink from screen
    President:
  • 2,692 Answers
Try isoproply alcohol lightly with a cotton ball.  Kep wiping lightly with new balls untill the ink is all absorbed into the cotton balls.
Posted on Jan 27, 2009
Tip
Getting a mother board out of your case
The support pins that hold up your motherboard have thes little squeeze pins and the trick to getting your motherboard off these pins is use a ball point pin with the ink and ballpoint removed press the hollowed out pin down on the motherbord pin (should be a perfect fit) and she comes right off.
on Jan 18, 2010 | Computers & Internet
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Swarovski pen won't write
Did you get an answer to this as my Swarovski pen is doing the same?
Oct 05, 2012 | Swarovski Crystalline USB Key Ballpoint...
Change refill in a franklin covey bristol mini pen
Hello, I have a Franklin & Covey Lexington ballpoint which looks similar to yours. To replace the refill pull apart the outer top and bottom sections, grip the plastic top of the refill and unscrew anti clockwise. Remove refill, replace and screw in new refill clockwise (but not too tight). Hope this helps.
May 30, 2012 | Franklin Covey and Bristol Mini Journal...
Faber Castell 148730 rollerball has been sitting unused for a few years and now won't write (no ink flow). There must be ink in the barrel because it was hardly used. Is there a way to restore the ink...
You can try running hot water over the tip of the pen for about a minute, then test the pen by rubbing it on a rubber surface. Hopefully that should loosen up the ballpoint and allow ink to flow freely again
Apr 28, 2011 | Faber Castell Graf Von Classic Rollerball...
Ballpoint ink stains on drum
There is a product called 'Goo Gone' , this will remove it for sure!
Aug 03, 2009 | Dryers
Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Open Questions:
LG Flatron 915FT 19" CRT Monitor Logo
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
