Question about Vacuums
My Bissell 3760-1 has stopped sucking in the roller portion. The grab n go part are working fine. Checked the belt and it looks fine. Did I burn up the motor or a microchip?
I have the bissell 3760-1 Grab N Go Turbo. It stopped sucking in the roller portion of the vacuum. The belt seems to be fine. Did I burn up the motor or a microchip in the vacuum.
  • Official Brand Answer
  • 315 Answers
Hey Lisa! Sorry you're having difficulty with your Lift-Off vacuum.
Here's a link to troubleshooting steps to assist you with the suction.
http://www.bissell.com/FAQDetail.aspx?id=1498&cid=ccsocial
Posted on Jan 22, 2013
5 Suggested Answers
SOURCE: Bissell 3594 vacuum won't suck..
Hello Bisselluser!
I had the same problem, and figured out it was the belt. Mine slipped off.
Just remove the bottom plate (four screws) and there it is!
I hope this works for you. Mine is working fine now. :)
Vist me at The Catbird Seat: http://thecatbirdseat.yuku.com/
Posted on Dec 30, 2007
  • 75 Answers
SOURCE: the Kenmore grab n go was sucking fine and then stopped sucking.
did you check to see if it is clogged?
Posted on Jun 29, 2009
  • 97 Answers
SOURCE: We have a Bissell Revolution Lift-Off Turbo 3760-1
these belts need to be changed every 6 months regardless of the way they look.
Posted on Jul 20, 2009
emissionwiz
  • 77201 Answers
SOURCE: brush won't turn bissell vacuum 3760-4
No there is no separate fuse, when you did this you caused the drive motor to overheat, this destroyed the belt as you have seen and likely burned out the motor for the brush head..
Posted on Dec 06, 2011
Testimonial: "Probably right, Dennis. I'll replace the brush head motor. Thanks for your advice. "
The roller brush on my Bissell Proheat Pet won't spin at all. The belts are fine, i already removed hair and debris, and it dispenses water, as well as sucks it back up.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?page=3&q=bissell&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 11, 2016 | Bissell Vacuums
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Brush won't turn bissell vacuum 3760-4
Dec 06, 2011 | Bissell Vacuums
I've changed the belt on my Bissell 3760-2 model but the brush still doesn't rotate. I've checked for clogs and there are none.
Clogs affect the air movement, but not the brush assembly. Remove the brush assembly from the vacuum base. Remove, clean, and lightly oil (with 3-1 or similar) the two end bearings. They are usually choked with debris to the point that they lock the brush roller. Reassemble it without the belt for a moment and check for free turning. If ok, install the belt and test the whole vacuum. Hope this helps!
Jan 29, 2011 | Bissell Lift-Off(R) Revolution(R) Turbo...
My Bissell Model 3760-4 is not working properly. The belt has been replaced (and checked 3 times), but the brush bar does not move when the brush motor button is on. The little metal turning piece that...
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
May 12, 2017 | Bissell Lift-Off(R) Revolution(R) Turbo...
Model #3760-2 Bissell upright vacuum- making very loud noise when running. Cleaned all filters- no difference
Is the noise coming from the belt area, ie. beater bar, or does it sound like it is coming from the motor itself? It is possible there is something caught in the brush roller.
When you turn the roller off, does the noise go away?
Dec 20, 2010 | Bissell Vacuums
I have a 3760 lift off bissell. Replace the torn
Did you get the right belt size? The belt you should have bought is this one:
Bissell 3760 Belt
Nov 08, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Burning smell when vacuuming, not belt
Try turning the vacuum on and hold the base up so you can see if the roller is turning. Odds are it is not and what you smell is the belt burning (not literally). If the roller is not turning, look for anything that is binding it - after you have unplugged the power cord. Probably the roller head is not fully aligned with the retention lugs that hold it in place or the belt is not properly placed on the roller itself, or if it is a used model, hair and twine can get tangled in the roller and cause it to stop turning.
Dec 26, 2008 | Bissell 5770 Healthy Home Bagless Upright...
Bissell 37602 roller stopped spinning
If the roller brush as stopped spinneng .and the brush motor still works the brush belt as broken,
you must replace the brush belt, t
Sep 05, 2007 | Bissell 37603 Upright Vacuum
Vacuums Logo
185 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
