Question about Traulsen Reach in Freezer - G12010
Traulsen G10010 wiring diagram - Traulsen Reach in Freezer - G12010
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Traulsen g10010 troubleshooting
Don't know this maker or model but if it is constructed like most modern units, the evaporator is under the bottom of the refrigerator and uses a fan to circulate air past it to dispose of heat taken from inside.
If this fan fails, either completely or because of excessive dust, the coolant is circulating via the compressor but the removed heat from the inside is not being removed from the evaporator.
Check for the presence and operation of this fan.
If failed, it can cause the problem you are having.
Most are accessible from the rear of the unit and are plugged in to permanent wiring so replacement might be quite easy.
Posted on Jun 15, 2008
  • 1253 Answers
SOURCE: need wiring diagram traulsen RDT 2-24-D
only way to get one is to call them at 1-800-825-8220. Give them model and serial numbers. There is nothing on line on their site.
Posted on Feb 28, 2011
  • 489 Answers
full service call video. Traulsen Refrigerator. Found bad motor and replaced. I hope it will help.
Posted on Dec 24, 2016
Traulsen wiring diagram
for what model? serial number helps too.
Jan 15, 2014 | Traulsen Reach in Freezer - G22010
Need wiring diagram traulsen RDT 2-24-D
Nov 08, 2010 | Traulsen Commercial 2 Door Cooler /...
How can I get the wiring schematic diagram for a two door stand up traulsen freezer model # GLT 2-32 NUT, Thanks Erick.
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
Oct 02, 2009 | Traulsen 46 cu. ft. / 1303 liter...
Traulsen reefer iced up,
electric heater must activate and warm to de-ice the evap coil in the correct amount of time ..elements setting under evap coils.ck for voltage to element leads while in defrost.You may wish to remove X terminal wire from defrost clock in order for the clock not to terminate early
Jun 17, 2009 | Traulsen G10010 Refrigerator
Traulsen 30" two door frodge 7 years old (just moved today)
Compressors don't like to be laid down, the rotor swims in lube that is disturbed when horizontal.
If the compressor isn't ruined, the noise could emanate from the fan that most units have, sometimes two; one to circulate air around the fins, another to stir air inside.
Pull the plug on the fridge while it is running and try to listen to the character of the noise before it stops.
If it is very rapid; I suspect the compressor is history.
If it makes kind of a singing noise while coming to a stop, it could be fan blades hitting something.
Jul 16, 2008 | Traulsen G10010 Refrigerator
Jun 15, 2008 | Traulsen G10010 Refrigerator
Traulsen Reach in Freezer - G12010 Logo
136 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
