I can not find any other replacement out there that will take the channel numbers off the TV
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
SOURCE: I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
This is the first time that I have used this site. I dont have the manual. I am not sure that you would be interested . I was looking to buy the remote control.
