Question about Intel S6240 Notebook
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
  • Kim Jaeger
    Kim Jaeger Dec 15, 2017
    minimise or close (doesn't matter which) all files and pages open, then holding down Ctrl and Alt press one of the arrow keys - left, right, up or down. Hope this works, my cat turned mine sideways, thankfully i figured it out!
  • Intel Master
  • 27,725 Answers
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Posted on Jan 21, 2013
4 Suggested Answers
  • 2386 Answers
SOURCE: Fujitsu lifebook s series get blue screen after
you may need to update wi-fi drivers, els re-installation of windows is recommended in particular case.
Posted on Nov 03, 2010
  • 18 Answers
SOURCE: how to totally change the
I am assuming, that it is presently Japanese. The only way to change all the languge is to install an English,(or other language),version of Windows. You can replace the Japanese version, or add the English version as a second Windows. The later will require double the memory space.
Posted on Nov 28, 2010
Geekman
  • 32281 Answers
SOURCE: My notebook (Fujitsu Lifebook S6000 series) screen
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
My fujitsu lifebook s7211,s series have startup
It seems like a hardware issue with the RAM you just put in. Please take it to the nearest service center and get it fixed. You may need to remove the RAM and reinsert it into the memory slot correctly. Also please check if the RAM matches the laptops specifications, ie, the laptop supports the RAM that you are installing.
Aug 31, 2014 | Computers & Internet
Rotate image
Most image software should be able to do that for you. I use FastStone Image Viewer which also lets you crop, rotate, resize pictures. It's freeware.
Nov 01, 2013 | Fujitsu LifeBook T4220 Tablet PC
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Computer wont come on
Did you installed the fjsecs Security Panel Application????...
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/Security.htm
Read this manual, maybe can help you.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-02EN-00.pdf page 26
To unlock the machine is completely necessary that you remind the password...
Just pres the display buttons in the order that you selected in the program.
http://static.phing.com/listings/48/481970/2882-8dc5j0_l.jpg
The buttons next to the power button at the right of the display.
There is a microphone symbol next to the buttons....
1 = a and arrow down
2= b and arrow up
3= rotate screen button
4= fn button
ent = alt.
If you selected http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/LIFEBOOK/E-Series/images/Screenshots/Image5.jpg
Example:
If you checked the boxes 1234 pres the buttons 123and4 at the same time.
next press ent (ent is next to power button)....
when you press any button that make a beep sound...
If the pass is wrong it will beep constantly for one minute..
other example: 1 - 2 - 14 - 4
in the first just 1 press 1
in the second 2 press 2
in the third 1 and 4 press 1 and 4 at the same time
in the fourth 4 press 4
finally press the button ent.
I hope you can access to your laptop....
Feb 06, 2012 | Fujitsu LifeBook T4220 Tablet PC
My desk top icons are upside down
Hi rsimuchoba...
To reverse the upside down screen mode , press contro,l alt, and the up arrow at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again.
Please take time to rate me
Aug 22, 2011 | Dell Dimension 9200 PC Desktop
Hi. I have a problem with my fujitsu lifebook t4215. When windows is runnning and I change the notebook to tablet config, I cannot get the display/screen automatically rotated. Even when I press the Screen...
Do you have Windows 10? As there may be an issue with screen rotation.
However to check your settings:
  1. Place the tablet into Pad/Tablet mode.
  2. Click the Start menu and select Settings.
  3. Click System.
  4. Click Display.
  5. Scroll down and check the status of Lock rotation of this display .
Jan 05, 2018 | Fujitsu LifeBook T4215 Tablet PC
The screen is staying upside down when it starts up
Press "CTRL + ALT + arrow key"
Arrows:
Left - Rotates screen to the left
Right - Rotates screen to the Right
Up - Rotates screen to back to normal
Down - Flips screen
Aug 22, 2010 | Dell Inspiron 1501 Notebook
Display problem in Fujitsu LifeBook C Series(c-6631
the internal bulbs of ur monitor screen have deteriorated...the manufacturers are real smart, these monitors dont last forever. So if repair estimate is too expensive then replace the whole unit.
Always purchase laptop or notebooks NEW or never more than 5 years old.
May 24, 2009 | Fujitsu LifeBook C6631 Notebook
Intel S6240 Notebook Logo
2,714 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
