Question about Mitsubishi LT-52133 52 in. LCD HDTV
Model 52149 has a vertical line running down middle and right edge of screen. does away after about an hour after tv is turned on.
3 Suggested Answers
jhinsincity
  • 616 Answers
SOURCE: I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
  • 10 Answers
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Posted on Aug 21, 2009
Vertical lines blue
Check area around TV for interference--cordless phone--wifi---also check input cords and hdmi cable or coax cable--- make sure connections are tight and secure
Aug 18, 2012 | Mitsubishi LT-52149 52 in. LCD HDTV
I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Oct 19, 2009 | Vizio Televison & Video
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Black line on middle of screen
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.)
Take your TV back if it is under warrantee.
Dec 11, 2008 | Hitachi SSH2442 Television
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Line through the middle
socer, solder connections on the vertical output IC are broken, board has to be taken out and re-solderering the pins on the vertical IC will fix it easy job for a tv tech, good luck, BMW Rider
Jan 03, 2008 | Proscan PS36123 TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
LCD TV - Vertical Blue line
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Mitsubishi LT-52133 52 in. LCD HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
