Question about Casio Exilim EX-Z750 Digital Camera
My Casio EX-Z75 Camera displays the lens error message what 2 do?
It was never Dropped with the lens extended or dropped at all for that matter. When the screen comes on it is very blurry and its out of warranty!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
3 Suggested Answers
arclight1217
  • 208 Answers
SOURCE: blurry pictures
IF YOUR PICTURES ARE BLURRY IN THE LCD, THEN YOU MOST LIKELY DO HAVE A PROBLEM. WAS THIS CAMERA BOUGHT ON AN AUCTION OR SECOND HAND, THAT YOU ARE NOT SURE IF IT WAS DROPPED? IF IT WAS DROPPED, IT MAYBE REPAIRABLE, BUT REPAIRS ARE USUALLY EXPENSIVE AND SOMETMES IT'S BETTER TO INVEST IN A NEWER CAMERA. SORRY, BUT I DON'T WANT YOU SHOCKED BY REPAIR ESTIMATES. FROM WHAT I HAVE BEEN ABLE TO FIND OUT, THE REPAIR COST WILL EXCEED THE COST OF THE CAMERA. SORRY. SO, CHECK THE LCD AND IF THE PICTURE THERE IS ALSO BLURRY, THE CAMERA PROBABLY HAS BEEN DROPPED AND OCCURRED SHOCK DAMAGE . IF THE LENS WAS OUT WHEN IT WAS DROPPED, YOU MIGHT TRY TO GENTLY PULL ON THE LENS WITH THE CAMERA ON. THIS SOMETIMES WILL ALIGN THE LENS AGAIN. HOPE THIS HELPS. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IT THIS WAS HELPFUL, PLEASE RATE!
THANKS!
Posted on Dec 18, 2008
  • 11967 Answers
SOURCE: My Casio ex-s12 was dropped and the lens won't extend or retract
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 21, 2010
Casio Exslim EX-Z33: Lens Error Message; Lens stuck
The camera might not of had been dropped or abused at that moment, but it sounds like one of your ribbons is not full connected to its port due to a previous unnoticeable drop or mishandling. In other words, if you are savvy enough to open the camera, remove the ribbons (2 of them, found on the front side of the camera coming from the lens) and re-insert them into their ports. I have only needed to do this once on this particular camera, but at least 30 times on the Exilim line of Casio cameras. Hope this helps.
Jul 18, 2010 | Casio Cameras
Lens won't extend. turned power on and error displayed, LENS ERROR. It stopped working after it was dropped.
This is probably THE most common failure among digital cameras, and one of the more common causes is dropping the camera.
There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 26, 2010 | Casio EX-Z150 EXILM DIGITAL CAMERA
Dropped my exlilim ex-s880 in the sand and can view pictures only
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
Blurry pictures
THANKS!
Dec 18, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
CASIO EXILIM EX-Z700 Lens Error
The only way to fix a lens error is to send it into repairs. Call them at 800-706-2534 option 2 and they will tell you the closest place to send it to.
Sep 14, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio EX-Z700 was dropped in sand. When camera is turned on lens makes a grating sound and the moniter screen is cloudy. It originally said lens error, but no longer says anything.
Hello, I'm Mark Faith from the states. I purchased the CASIO EX-Z700 series.
However, I accidentally dropped the camera when the camera was on and the lens was extended.
It makes a grating sound, and the monitor screen said "Lens error".
Now, the camera is turned off with its lens extended.
When I see the lens from the top, the lens position is more concentrated to the right, and the gaps between each lens is bigger on the left hand side of the lens.
I sincerely hope this would help you to analyze the lens situation.
I'll be patiently waiting for a list of solutions.
Thanks.
Mark
Aug 06, 2008 | Casio Cameras
Resetting EX-V7 error message
Hey Go here
http://world.casio.com/qv/download/en/ex_v7_firmup/
Download the latest firmware. Install it. Like the rest of the people. It seems like we all dropped it. And updating the firmware seems to help a bit.
Meaning you can now use tha Camera and take pictures, but when you turn it on, you will get the same error message for like a second. Then the Camera is back to normal.
If its under warranty take it back. And dont tell them it was dropped.
Cheers !
Mar 14, 2008 | Casio Exilim EX-V7 Digital Camera
Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Dec 14, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
81 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
