Question about i-mate K-JAM Cellular Phone
My i-mate k-jam IS NOT TURNING ON!!!
Well i turned my i-mate of one night and in the morning it would not turn on i tried to reset it, i took out the battery and cleaned all the back of it, it was fully charged but it will not turn on
help please?
  • volschenks Apr 26, 2009
    I let my kjam's battery run completly flat (its supposed to make the battery last longer) but when I tried to switch it on nothing happened. I've tried charging it (through the computer I dont have the charger) the best i've mannaged is to get it to the i-mate screen but then it freezes and will not charge. This only happens after I've left the battery in the sun so that it can get a **** charge. Any help will be appreciated!!!
Take your imate kjam battery out, then get 3 aaa battery connect them like this
-//////+-////+-////+ connet a wire on the negtive side of the aaa batterys and a wire on the postive side. then connect the wire to the imate battery, you will see a red dot which postive and black dot which negtive and keep it connect for 30 sec and then put back the imate battery back (it should start)
the imate battery looks like this
123456
Posted on Jul 30, 2009
My phone, the Droid X, keeps randomly turning itself off and also turns off during phone conversations. If I have my alarm set to wake me in the morning if I get a text during the night and I'm not awake...
I have a droid x and keeps turning off and on randomly, I took it to Verizon and they factory reset the phone and reset the battery but it didnt fix it! so I end up getting a new one on the mail!(warranty) but the new replacement does the samething! took it to verizon store and they did the samething, except that this time, they gave me a new battery! but stil does the samething! can someone help me with this?
Jan 07, 2011 | Cell Phones
Phone turning on issues
the solution for this problem is charge one hour with your blackberrycharger and make sure that you are not connecting to your pc for charging.then switchon the handset
Aug 10, 2009 | RIM BlackBerry Pearl 8100
My motorola i290 won't turn on no matter what!
I FINALLY GO IT!!!!!!!!!!!!....take the battery out 4 a few secz n pop it back
Aug 04, 2009 | Motorola Mobility I335 Cellular Phone
Turn off machine at night?
Turning off an espresso machine at night is a bad idea. There are many gaskets and seal's that mate to different types of metal surfaces all of which contract and expand at different rates when hot or cold. If you keep doing this you will eventually break the seals.
Jan 02, 2009 | Espresso RMI La Cimbali Espresso Machine
I-Mate Jam Power On Problem !
hi,
my phone disply not working
please help me!
call me -09847017961(India/kerala)
Oct 20, 2008 | i-mate JAM Pocket PC
K JAM
that happend to me once, i totally freaked out.... try turning it completely off, remove the sd card, then turn it back on.
once your phone has finished booting up (and all programs have finished loading), put in your SD card.
If that doesn't work you could always hard reset the phone (sometimes that fixes it)
Jun 25, 2008 | i-mate K-jam Smartphone
Printer error code
E-3 indicates a paper jam. Turn the power off. Try removing the paper and lift up the scanner top to see if there is any paper, debris, or foriegn object in there. Gently remove anything you find. Turn the power back on and press the start (black or copy button) and hopefully you will have cleared the problem. If not, you can try to reset the machine by turning it off, unplug it from the power source and remove the USB cable if it is connected to a computer. Plug it back in and turn the power back on. If this still does not clear your error, it may need to be serviced. I had this same problem last night. I did not find any paper jammed, but there was a small black twisty tie stuck in under the roller - it took me several tries and over two hours last night and another 2 hours today to discover the problem. It works fine now. However, before my second try at fixing it today, I had given up on it and purchased another printer online. Now what will I do with two? Hope this helps you. You can also try calling Canon tech support at 1-800-828-4040.
Nov 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
I-mate jam
HARD RESET PROCEDURE
hold down the power button and push the reset. You don't have to use a paper clip if you've styles fits, but don't use anything sharp, such as a safety pin. This should return your PDA to the way it came from the box.
before that backup ur all data
Nov 10, 2007 | i-mate JAM Pocket PC
i-mate K-JAM Cellular Phone Logo
464 people viewed this question
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
