Question about Uniden 5.8GHz Dual Cordless Phone
UNIDEN POWERMAX5.8 SATILITE CONNECTOR NOT CHARGING PHONE. IF PHONE PUT ON MAIN CHARGER, IT WILL CHARGE.
    Problem Solver:
  • 16 Answers
Either the connectors have something in them like food or alot of dust or something laying in the cradle that is keeping the contacts from touching the phone contacts. Look in the cradle to see if there is something in the way, If that dont work, make sure the power socket is good by plugging something else in the outlet just to be positive it is hot, if it still won't charge then the plug on the cradle is bad or torn off inside. If you are a wizard you could fix it but if you are not inclined to tear things apart and out them back together don't try it. Good Luck...
Posted on Feb 15, 2009
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
LG Neon won't charge. It's not the charger.
First turn off the phone remove the battery and put it back in, then try to charge it, make sure the charger is properly inserted in the phones charging port.
Try out the charger on another phone to confirm if it is still working. Then you try another charger on the phone to confirm if the phone is faulty. If the charger does not work, then the problem is from the phones charging port.
To repair that, have the phone opened then either resolder the carging port to the main panel or you replace the charging port with a new one.
For the main time, you can use a universal charger, but that will require you to have an extra battery so your phone will not be off when charging the battery.
Take care and good luck
Oct 28, 2010 | LG Neon GT365 Cell Phone
How to charge the battery of a new uniden phone?
if u have that phone charger mens u can charge that phone
Apr 04, 2010 | Uniden Cordless Phone
My power connector on the phone came loose and now it won't charge.
That should be the charging port. You need to get it replaced.
Main while, you can use a desktop charger to charge the battery separately till you get you charging port fixed.
Safe.
Dec 29, 2009 | Sony Ericsson W760i Cellular Phone
Car charger not working. Is there any other way
did you get a pc usb cable in the box? you can use that to charge it. Also you can get a wall plug charger. all you need to do is obviously figure out what the connector is and find a charger to match, or if you want you can get a mulit adapter mobile phone charger you know the ones with all the different heads to try and fit any phone. That should be the same voltage as what the sat nav uses.
Oct 24, 2009 | Uniden TRAX-438 GPS Receiver
Phone suddenly not charging
check out the charging connector wher u put charger in phone there would be carbon clean one by one with some kind of safty pin
Jun 14, 2009 | Sony Ericsson K300i Cellular Phone
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
Charging Sagem my401c - error
Charging errors occur when the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Aug 05, 2008 | Sagem my401x Cellular Phone
Uniden 5.8GHz Dual Cordless Phone Logo
131 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
