Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Model z-110 white powder build-up around the outside end of the motor. no water leaking at this time. motor runs on 240 v. BOB ADAMS
MOTOR WAS REPLACED IN 2004 WITH NEW ONE. WHITE POWDER RESIDUE CAKING UP AROUND THE END OF THE MOTOR. NO LEAK NOTICED AT THIS TIME.
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 52 Answers
White powder build up would indicate to me calcium deposit but calcium is usually a pretty hard caked on product once produced.
Coming out of the back of the motor is usually caused by the friction of the windings working.
Rod
www.uspartscenter.com
Posted on Feb 01, 2013
Wirinmg diagram for SEARS12" tablesawMod#11324181 Serial# 7297Poo56
Please contact Sears on this, we do not have these diagrams here.
Dec 02, 2016 | Pool & Spa
Ge older model dishwasher, filled with water , but wont run its cycle, I have motor and cycle noise
If you have what looks like a white disk in the center, you need to clean around the outside edge of the disk and put a thin layer of good high temp sillicone around it and wait a full day before using it.If the outside edge of the disk leaks the washer will fill and run but will not drain.
Apr 24, 2016 | GE Dishwashers
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Dec 07, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Heater fan does not work when below freezing outside
There could be water entering the blower motor that is freezing and not letting the motor spin. You can remove the blower motor and inspect for water. If there is water in the motor... the source of the leak will have to be pinpointed.
Dec 06, 2012 | 1999 Ford Explorer
I have 240 timer switch and I wana use it for 120 ? How can I do that?
if the switch is rated for 240, then hook up the same way but use the 110 black and white wire for 110 volts to switch, instead of the red and black wire for 240 . on 110 black wire is always hot and the white is the neutral wire. the best wire to use is 12/2 with ground.
Jun 20, 2011 | Water Heaters
Why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Dec 24, 2009 | Air Tools & Compressors
White powder coming from the heater vents
its a fungus from running the air the drain hole is probably clogeed and it dont drain right so calcium builds up try running the heater and spraying lysal in the vent on the outside by the windshield
Dec 09, 2009 | 2007 Ford Edge SEL Plus
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
No visable leaking, always smell coolant when motor is hot, outside of the 2003, 3.3liter grand caravan. Gauge will read half way after 3mins on a cold start, takes about 8mins for any heat to come from...
If you smell coolant then there is a small leak, it is most likely the water pump shaft seal, look for stains, coolant leaves a white powder when it dries, look on the underside of the hood for any coolant stains from it been flung there by the spinning water pump. Also have a radiator pressure test run, good insurance aginst an engine overheat if leak worsens, engines are very expensive to repair if overheated badly.
Oct 07, 2008 | Dodge Caravan Cars & Trucks
The ice cubes come with white powder
Hey there....
The white powder in your ice cubes is the water line to the dispencer,The water in the pipe forms a white layer after some time,almost like the kettle around the aliment,you just have to clean the pipe out,i normaly use some hot water with a bit of vinigar,just make sure you flush the system after wards and there you go....
Hope you get it right...
Wouter.
Sep 10, 2008 | Frigidaire FRS26R4A Side by Side...
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
65 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
