Question about Acer Computers & Internet
CAP LIGHT DOES NOT COME ON - Acer Computers & Internet
  • Acer Master
  • 27,725 Answers
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Posted on Jan 22, 2013
  • Jim Blanck
    Jim Blanck Jan 24, 2013
    THANK YOU VERY MUCH FOR YOUR HELP AND SUPPORT, DEEPLY APPRECIATED,,
  • Brian Sullivan
    Brian Sullivan Jan 24, 2013
    no problems hope it all worked out
Gas cap indicaytor light came on. Changed cap and made sure it was tight but indicator light still comes on
The gas cap light is a generic light that indicates an emission problem. Usually a vacuum/pressure leak within the system. The gas cap is usually the first thing to check, however may not be the problem. There are numerous sensors and lines that control the vacuum/pressure/ of the fuel vapors and one of these is loose/disconnected/defective causing this light to come on. I would recommend inspecting hoses under the hood for any that may be loose/disconnected. You may also require a scan test to view sensor data to isolate the source of the light
Dec 29, 2015 | 2008 Chrysler Sebring
My check gas cap light and check engine light is on
CHECK GAS CAP COULD BE LOOSE OR MISSING OR LEAKING CAUSING EVAP LEAK IN WHICH WILL CAUSE CHECK ENGINE LIGHT FLASH ON..
Sep 20, 2011 | Mercury Monterey Cars & Trucks
There is condensation around the exhaust pipe is this a problem plus the gas cap light comes on
Condensation on exhaust pipe is normal.
Gas cap light:..This may be caused by loose or leaking hoses, loose or broken fuel cap, a leak at the top of the fuel filler pipe neck, ect......
Aug 22, 2011 | 2001 Ford Mustang
I'm getting gascap error and check engine light. What's causing the issue?
If you allready checked the gas cap and its on right.
Try replacing the gas cap with a new one.
You should here air wen you open the gas cap after driving
This is part of the emision controls and if it dosn't seal it will cause the check engine light to come on .
Jul 28, 2010 | 2007 Dodge Ram 1500 Quad Cab Sport
Gas cap warning light is on. Gas cap is tight.
If the cap is tight then you need to replace the fuel cap. the light will go off when cap is replaced
Jul 13, 2010 | 2000 Dodge Caravan
FUEL CAP LIGHT ON
Hi:
The check fuel cap light is tripped when your cap has been loose or off, and the engine is running. Often you need to have the light reset by a code scanner. If you have checked the cap and it is secure, if you reset the code and it comes back, you possibly need a new gas cap.
Nov 25, 2009 | 2006 Honda Accord
2005 check engine light comes on. had advanced
If the light is out, no worries. if it comes back on and the cap is tight, there may be other problems and a qualified repair shop will need to diagnose that for you. It may have a Evaporative Emission Leak.
Nov 10, 2009 | Chevrolet Cavalier Cars & Trucks
2007 gas cap light comes on then the ckeck engine
try replacing the cap itself.
make sure its on tight untill it clicks a few times.
Jun 18, 2009 | 2005 Buick Rendezvous
Light on my dashboard
ford taurus's are well known for this. the seal on the gas cap goes bad. before you replace the gas cap make sure when you close the gas cap you are turning it at least 5 clicks. if light stays on get a new gas cap. they are easy to install all you need to do is remove the gas cap.remove the gas cap strap. put ******** the new cap, close cap and turn 5 clicks. not clicking 5 time can set a p400 or p401 evap code causing the check enging /ses light to come on.
Apr 19, 2009 | Ford Taurus Cars & Trucks
Check engine light
Sorry your going to have to change the gas cap. You can try  spraying WD-40 to the rubber seal on the gas cap to get you some more months out of it, the seals get hard and don't seal any more. Good luck
Apr 08, 2009 | 2004 Toyota Prius
Computers & Internet Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
