Question about CDV Software Glory of the Roman Empire for Windows
Glory of the roman empire sound dropout - CDV Software Glory of the Roman Empire for Windows
Tip
How to Remove Scratches in Stainless Steel
Whether you can remove a scratch has much to do with how deep the scratch goes. Here are several ways to deal with this problem and restore your cookware, stainless steel appliances, countertops or sinks to their former glory.
Consider using a product made for stainless steel such as Scratch-B-Gone or Bar Keepers Friend.
Or, try spraying an all-purpose cleaner (such as Formula 409) on the scratches.
Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
Rinse the surface and wipe dry.
You may also use a solution such as WD-40 to help fill in the sctraches and coat the stainless steel on the unit(s).
on Oct 19, 2011 | Frigidaire Refrigerators
How to disable shutter sound of alcatel 918N glory x?
Oct 07, 2012 | Alcatel Lands Phones
Who were the first germanic barbarians to invade roman landsand when
GERMANIC QUADI and MARCOMANNI 167AD: the Roman empire is attacked for the first time by barbarians (the German Quadi and Marcomanni)
reference: http://www.scaruffi.com/politics/romans.html http://home.tiscali.nl/~wr2777/Quadi.htm
Aug 30, 2011 | Computers & Internet
Dropout
whats cpu specks u have alot ram hi end sound and video /> power
Jan 05, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Freezing
Spec's look decent but many things can cause this problem, a lot of them fall under 'settings' and 'drivers'. Making sure ALL BIOS settings are set correctly is foremost. Clear the ESCD in BIOS after any hardware change. Make sure frequency and timing settings don't cause excessive wait-states for BUS x-fers. After BIOS is checked, ensure MoBo 'chipset' drivers are installed - full AGP functionality may not be possible without them even though Windows installs 'generic' drivers. All hardware mfg. drivers should be installed and settings checked. Make sure not infected with badware. Disconnect any hardware not needed for gaming, or disable drivers like multimedia enhanced keyboards and any system processes or background tasks that are not essential so there are less things causing IRQ requests.
Make sure DMA is enabled for HDD and CDROM's if supported by them. Error-scan, defrag and check S.M.A.R.T. status of HDD's. Use a sys info tool like 'Everest' or 'PC Wizard' to check if settings in BIOS and OS are allowing full hardware functionality.
Some hardware (and software) just don't play well with certain others lol, so if all that fails, borrow another video card with similar features and see if it works better before spending money on a new one. Check if your MoBo chipset has known issues with any of the different graphics chip mfg's.
Good luck and hope it turns out to be something simple ;)
R.M.T.
Nov 21, 2007 | IBM ATI RADEON 9200 Pro 64MB Video Card...
CDV Software Glory of the Roman Empire for Windows Logo
66 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
Bill Boyd
EnergeeUK
Level 1 Expert
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
