Question about Toshiba Colored Back Cover For Thrive 10" Tablet Raspberry Fusion In Package
AT 300 tabet hack - Toshiba Colored Back Cover For Thrive 10" Tablet Raspberry Fusion In Package
P1000 10.1 polaroid tablet. How can I get keyboard to work?
Hi they r cheep to buy on E/BAY APROX $23. THIS WOULD B THE BEST WAY TO FIND OUT IF IT IS THE KEYBOARD OR YOURE TABET THAT IS AT FAULT CHEERS
Mar 07, 2016 | Polaroid Tablets & eReaders
How do I do hard reset on Nobis 9" tabet?
1. shut down the tablet
2. hold down the power key and the volume down key
3. when recovery mode shows up, release the keys. navigate using the volume up key and when "wipe all user data" is selected, press and release (don't hold!) the power key.
4. wait until it says "done"
5. restart the tablet. your tablet should now be reset!
hope I helped!
~Conner
Nov 28, 2015 | Tablets & eReaders
How I down load games on my kurio tabets
Depends on where you are downloading the apps from...Kurio Store? Google Play Store?
Did the app get loaded to a user's profile?
Try looking here: Getting started Kurio Touch 4S Kurio Tablets
Jan 11, 2015 | Techno Source Kurio Kids Tablet With...
How do I reset my 7 inch polaroid tabet to factory defaults?
Patty, I'm first assuming you can at least boot the tablet to the menu screen. Scroll over to the settings menu. Scroll down the settings menu to backup and reset. You then have two options given: Back up my data or Factory data reset!
Oct 18, 2014 | Polaroid 7" Internet Tablet Android 4.0...
My tabet wont turn on
First make sure your charger is working properly. Check it with a volt meter or use a friends charger that you know is working. Charge your Coby Kyros for 4 hours. Use a small needle and gently insert in into the "reset" hole on the back cover on the left side. Hold it down for 5 seconds then release. Try restarting your tablet. If these don't work, you will have to get professional help to check it out.
Feb 12, 2014 | Coby Kyros 716829701508 Tablet PC
How can i get android apps in my tabet
a rt tablet is NOT a android tablet. it runs a leaner windows based live tile system called windows 8 rt. you cannot get pure android applications on the asus but you developers will port applications over to other operating systems so you may be able to get a different version or something simlar on that kind of tablet if the developer made it.
Dec 08, 2013 | ASUS VivoTab RT
Tabet shuts off when attatched to power cable
Try going to settings --> Developer options --> Stay awake
This way the screen shouldn't sleep when charging and you can see what is happening.
Also look at any power saving apps you have to see if they have setting to turn off/sleep when charging.
Dec 05, 2013 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Toshiba Colored Back Cover For Thrive 10" Tablet Raspberry Fusion In Package Logo
Top Toshiba Tablets & eReaders Experts
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
