Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 365 compression
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Hi, I'm looking for a Husqvarna 365 chainsaw sprocket cover
No response to CR.
Posted on Apr 09, 2010
  • 4088 Answers
SOURCE: MY hUSQVARNA 365 372xp CHAINSAW
Likely, the saw has been run with straight gas--no admixed oil. When this occurs, the piston, ring(s), and cylinder wall will have been deeply scored. Remove the muffler and turn the motor slowly while watching the surfaces of the piston, ring(s), and cylinder wall. If these surfaces are not smooth, then replacement of these parts is necessary. (very expensive with parts and labor) Hope this helps!
Posted on Oct 19, 2010
My husqvarna 365 special stalled out yesterday while cutting a tree , it started back up after sitting for 10 minutes , now it won't start at all . It's getting fuel but not starting .
Check you have a spark, check the compression psi and check fuel is getting into the cylinder. Then reply with more info please
May 18, 2016 | Husqvarna Garden
Chain saw runs for 15 min then cuts out ?
could be several things, first always inspect the cylinder for scoring, if there is scoring there will be compression loss once the saw warms up, second check for fuel hose damage either in the tank or out side of the tank, third, ignition coil could be shutting down after it gets hot.
Jul 14, 2014 | Husqvarna 362 365 371 372 385 570 575 576...
I found there is a Malaysian made piston/sleeve complete set for Husqvarna(365) chain saw and its very cheap .so far so good..if you have any experience about this please let me know.
You pay your money and you take your chance, i have seen some very poor quaility pirate parts, do not expect it to last too long, tollerences and coatings are usualy the issues.
Jul 11, 2012 | Husqvarna Garden
Husqvarna 365 backfireing
Check your spark plug for 'whiskering' (tiny strands of carbon collecting across electrodes) and clean and re-gap. If this not the problem, check carburettor fixing to engine - may be drawing air through failed sealing gasket. Good luck!
Jun 09, 2012 | Husqvarna 362 365 371 372 385 570 575 576...
How much oil do you have to mix with fuel for a Husqvarna 365 special chainsaw?
50:1 is the fuel to oil ratio. Most oil bottles have dispenser guides for a gallon of fuel. Be sure to use a modern synthetic saw oil and fresh gas. Shake the container thoroughly each time just before adding fuel to the tank to prevent oil starvation. Hope this helps!
Nov 13, 2010 | Husqvarna Operator's Manual 365 372xp ...
MY hUSQVARNA 365 372xp CHAINSAW WIL NOT START. LOW COMPRESSION
Oct 18, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How to install a new tension screw on a husqavarna 365
I have never done this but with the IPL as a guide it looks pretty simple.
Use care; it is easy to trigger the chain brake and is most difficult to reset with the cover off the saw.
Remove the clutch cover (brake off)
Husqvarna 365 IPL example (may not be your saw)
http://weborder.husqvarna.com/order_static/doc/usa/1999/I99000/I9901064.PDF
Detail A (clutch cover)
remove 2 each - 503 21 28-10* screws
remove 537 01 68-01, all parts now accessible.
Find your IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
GL
Lou
Nov 25, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
14 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
