Question about Black & Decker CC800 Shredder
The forward doesn't work, but the reverse works, what's wrong
I got my 2001 dodge ram 1500 with the 5.9L v8 stuck in the sand at the beach. While my buddy was pulling me out from behind, I was flooring it in reverse to get out. Then my my rpm went down and the...
Need more info: is manual shift if so 4sp ,5sp or 6sp speed?
or auto w/overdrive ?
2) wont go into gear or selects reverse gear but acts
like no gear?
3) does forward gears work?
4) how's the fluids?
Jan 30, 2013 | Cars & Trucks
My sewing machine now only sews in reverse
Maybe there's a problem with the reverse and forward button.
For sewing machine reviews
Sep 26, 2012 | Sewing Machines
My toyota doesn't work in drive if you bring the RPM up to 6 it will slowly move forward it works great in reverse though
As a home mechanic there is only one thing you can easily do, check the fluid level in the trans and change it if it is dark brown or burned smelling
Mar 14, 2012 | 1994 Toyota Camry
1996 Jeep Grand Cherokee. Transmission problems. when the gear selector is in reverse, it doesn't engage in reverse. When you go to neutral, it drives forward but doesn't shift through the...
Put the vehicle in Park, disconnect the shifter from the shift lever on the trans, adjust the linkage or cable so the connection is clearly a slip in/on connection and tighten things back up. Hopefully this will solve your non-reverse. As for all the gunk and metal shavings, friend, you better have another tranny standing by in your garage when this one stops working completely.
Jun 09, 2017 | Jeep Grand Cherokee Cars & Trucks
Mitsubishi outlander 4x4 - 2005 light stays on when changing from 4x4 to 2 wheel drive
Try this quick fix solution.
Put vehicle in park or neutral, press the switch or turn the dial to 2H, put vehicle in reverse and reverse the vehicle aproximately 10m's or around 30ft.
Now drive vehicle forward, and this should unlock the 4wd mode.
If this doesn't work then your solenoid may need replacing.
Jul 31, 2011 | 2005 Mitsubishi Outlander
The reverse forward feature doesn't work
To advance the slides forward just tap the advance button. To revers it hold the advance button down. If that doesn't do it it will need service.
Nov 12, 2010 | Braun Novamat 330 Slide Projector
Stopped working while i was using it
Mine does that when it jams, or overheats. Try toggling the switch between forward and reverse to clear any jam. If that doesn't work, you can unplug the unit, turn it over, and remove jammed paper with needle nose pliers.If there is no jam, try letting it cool for a while and then try in the reverse position.
Oct 29, 2010 | Staples ID Armor IDX50B Shredder
Black & Decker CC800 Shredder Logo
32 people viewed this question
Top Black & Decker Office Equipment & Supplies Experts
Tony
Ngoro
Ngoro
Jerry Kramer
Jerry Kramer
Are you a Black & Decker Office Equipment and Supply Expert? Answer questions, earn points and help others
